Part #'s Bilstein HD's for 911SC
Upgrading my suspension for my 1978 911SC. I want to buy the Bilstein HD for front and rear. I am getting a little confused on what part number is for the HD's. Looks like rear are 24-001694 and fronts are 34-001127. Are these the correct part numbers for Bilstein HD's?
Gavin
Old 03-27-2022, 05:29 PM
Bilsteins
I have Bilstein HD’s for F/R in original boxes if you’re interested, I decided to go with with the KW V3 suspension setup.
Front: F4-B36-5001-H0
Rear: F4-B46-0169-H2
Mark
Old 03-27-2022, 07:44 PM
I'd like to know more about the 1127s as well. I have a set and while they're green, there isn't a ton of good info on if they match the valving we'd call HD. I believe they are based on what I have read, but its been a bit since I was mid-way down that rabbit hole.
It seems unless you're ordering from a supplier who has the decoder ring, the part numbers Bilstein provides aren't matched up so cleanly with the original Porsche numbers used when ordering shocks under the HD or Sport name.
Old 03-28-2022, 05:29 AM
Bill Verburg's Avatar
Gavin
34-001127 are the inserts only for oe Boge struts 2115/755 towards the track end for these
24-001694 are the rear shocks 1965/1330 green by far the most street version
Are you looking for inserts or the full Bilstein strut?
Bill Verburg
Old 03-28-2022, 08:51 AM
