Part #'s Bilstein HD's for 911SC
Upgrading my suspension for my 1978 911SC. I want to buy the Bilstein HD for front and rear. I am getting a little confused on what part number is for the HD's. Looks like rear are 24-001694 and fronts are 34-001127. Are these the correct part numbers for Bilstein HD's?
Thanks Gavin |
Bilsteins
I have Bilstein HD’s for F/R in original boxes if you’re interested, I decided to go with with the KW V3 suspension setup.
Front: F4-B36-5001-H0 Rear: F4-B46-0169-H2 Mark Last edited by G450X; 03-27-2022 at 10:34 PM.. |
I'd like to know more about the 1127s as well. I have a set and while they're green, there isn't a ton of good info on if they match the valving we'd call HD. I believe they are based on what I have read, but its been a bit since I was mid-way down that rabbit hole.
It seems unless you're ordering from a supplier who has the decoder ring, the part numbers Bilstein provides aren't matched up so cleanly with the original Porsche numbers used when ordering shocks under the HD or Sport name. |
24-001694 are the rear shocks 1965/1330 green by far the most street version Are you looking for inserts or the full Bilstein strut?
