Headlights don't work
1975 911S not sure when they stopped working because don't drive the car much after dark all other lights work but no headlights high or low beam any ideas thank you
Old 05-03-2022, 07:04 AM
Really opening yourself up here…
Have your checked the fuses? Wiring? Anything loose? Do you have a voltmeter?
Ass-engine Nazi slot car -- PJ O'Rourke
Old 05-03-2022, 07:50 AM
Test light, go thru the wiring clean fuses and fuse contacts, could also be dimmer switch….
Old 05-03-2022, 11:22 AM
ROW '78 911 Targa
timmy2's Avatar
Bulbs still good? Run a jumper from positive battery terminal to the lower side of headlight fuses to see if they light up. Momentary check.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-03-2022, 01:59 PM
That happened to me on my 85 Carrera. Low beam went out then high beam. It was the combo stalk switch on the column. The switch that controls turn signals and hi lo beam
Tim
Old 05-05-2022, 08:26 PM
Headlight switch
$500 +
Ridiculous
Old 05-06-2022, 07:39 AM
