Seeeu911's Avatar
Question dum dum tape ? is that the name ?
See this tape/insulation black sticky on the evaporator ?
where can I buy some more ?
Auto part stores dont seem to to have it.
I remember it used to be called dum dum tape or such ?
your input is most appreciated !
Old 07-05-2005, 01:54 PM
It has a few different names. Here's a thread with the info you seek: fender installation putty....
I'd think any auto body supply store will have.
EDIT: The black stuff in the pic may be something different.
Similar to what's used on my central air connections at home. Perhaps similar to this: http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?prod_id=300363&cm_mmc=1hd.com2msn-_-product_feed-_-D27X-_-300363&srccode=cii_9686437&cpncode=08-304008-2
Worth a trip to Home Depot and $4.98.
Warren & Ron, may you rest in Peace.
Old 07-05-2005, 02:05 PM
Seeeu911's Avatar
Thanks RickM, I've got some of that sealer strip and its great for all kinds of sealing. this black tape seems to have insulation qualiites ? almost asphaltish.. the PO removed it from the expansion valve and placed it over the old falling apart vent duct hose.. A new vent hose is on now, but this stick tape is all used up.
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 07-05-2005, 02:16 PM
I added to my original post. I agree with it having insulation properties....
Old 07-05-2005, 02:24 PM
Prestite Tape:
http://www.acsource.com/index.asp?PageAction=VIEWCATS&Category=230
Old 07-05-2005, 03:08 PM
rfuerst911sc's Avatar
Seeeu911 where in Orlando are you? My winter project was R+Ring my AC system and I purchased a roll of prestite tape, you only need about 2 feet for the job and that's being liberal in application. Send me a PM and we can hook up and I'll give you 2 feet of the stuff. You can see my setup and maybe it will help you out. Let me know..............Rick
Old 07-05-2005, 04:22 PM
Seeeu911's Avatar
Thanks guys ! Thats it Jim.
rfuerst911sc you have PM !
to help you unravel
Old 07-05-2005, 05:43 PM
Hey, you still got that roll of the dumdum? Let me know and we can coordinate a time and place to meet. I'm in serious need of that stuff!
Old 03-16-2022, 05:39 AM
Northern Motorhead
wildcat077's Avatar
Actually it's called gum-gum tape ... we use it to do bagging repairs on composite structures.There's all kinds of applications for that stuff and similar products, i'm sure it's readily available by many sources.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-16-2022, 06:34 AM
That asphalty stuff on the expansion valve is a nightmare to remove once it's aged. Comes apart chunk by chunk with a razor and a scraper.
1982 911SC
Old 03-16-2022, 06:45 AM
Hardware store near the window, door weatherstrip supplies, comes in a white roll.
Old 03-16-2022, 07:13 AM
New-ish 911SC Targa Owner
pampadori's Avatar
your nearby FLAPS carries the black 3M brand window-weld ribbon sealer as its called.
I use this stuff to apply vapor barriers to the doors behind the door cards and also to seal up behind trim and under seals at what not. You can use it as a string or you can wad it up and make it whatever shape you want it to be.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 03-16-2022, 07:34 AM
scumbag
You can also find it by searching for 'butyl rubber' or 'butyl tape'.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 03-16-2022, 08:33 AM
Walt Fricke's Avatar
I bet shops, like the ones I have used, still call it "dum dum." I bought some from Porsche or as a Porsche part. It might be P/N 000 043 192 00, or some later replacement, which is called a sealing strap and goes under quarter window trim. Was a rather large (read a lot of this adhesive and malleable strip) roll, with blue thin plastic separating the continuous strips from each other.
Useful for filling gaps at the corners of the windshield, too.
Old 03-16-2022, 02:33 PM
