Too many sensors!
'81 SC. The factory 3.0L engine has what appears to be four temperature sensors and two pressure sensors on it.
Right chain case lid temperature switch: 930 606 117 00 Left chain case lid temperature switch: 911 617 117 00 Oil breather cover temperature switch: 930 606 117 01 Front of engine remote temperature sensor: 901 641 632 00 Front of engine oil pressure transmitter: 911 606 111 03 Top of engine oil pressure switch: 911 606 230 00 I'm operating under the assumption that all four of the switches tie in to the same oil light on the druck/temp gauge. Is this correct? If not, what are they used for? That leaves a single oil pressure sensor and one for temp. Why are these at the front of the engine? Is there a difference in pressure between the front of the engine and the breather tube lid? What about temperature? |
Left chain case lid temperature switch: 911 617 117 00 - thermo-time switch (TTS) - grounds the Cold Start Valve (CSV) for extra enrichment while cranking for cold starts below a set temperature Oil breather cover temperature switch: 930 606 117 01 - dunno , my turbo had something different there. probably related to CIS warmup in some way.Front of engine remote temperature sensor: 901 641 632 00 - I believe this one drives the gauge, but would have to check wiring diagram Front of engine oil pressure transmitter: 911 606 111 03 - pressure sensor, drives the gauge in the dash Top of engine oil pressure switch: 911 606 230 00 - "idiot light" sensor, drives the warning light in the gauge At least one of your temperature "switches" is actually a sensor that drives the temperature gauge. Would need to look at the diagram be sure which one. Pretty sure the other temperature switches do "stuff" to CIS - most likely to alter the way it behaves during warmup. Quote:
The temperature sensor drives the gauge, The TTS drives the CSV for cold starts; I suspect the other temperature switches control CIS warmup in some way (but my 930, which originally had CIS as well, never had these - so sorry, dunno )
'77 S with '78 930 power and a few other things. Last edited by spuggy; 03-25-2022 at 11:40 AM.. |
TJ, Find a good reference manual for your car and learn the basic instrumentation. A Bentley SC Manual although has some typos is still an excellent reference manual. To answer your question, only one of the switches you mentioned controls the idiot light on the dashboard. The other thermal switches operate at different temperatures namely @ 15°C, 35°C, and 45°C. The individual temperature switches are marked accordingly on the switches. Bentley has good pictures and description how they work. Tony |
- the temp switch on the right chain housing is a 15 °C switch, which opens beyond 15 °C and lets the ECU switch form Open Loop (no lambda regulation but fixed value far static enrichment while col running - the tempmswitch on the oil breather cover on top of thge engine is a 35 °C switch, which closes beyond 35 °C – it tells the ECU that beklow 35 °C it should extra enrichen when accellerating from idle. All mentioned here: https://nineelevenheaven-wordpress-com.translate.goog/der-911-us-sc-3-0-motor-mit-g-kat/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp (Google translated till I translate to english – or someone else :-) )
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
ROW '78 911 Targa
For your Carb conversion, You only keep the oil pressure switch by the breather and the oil temp and pressure senders up front.
All the others are Lambda system related and are not needed.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 03-26-2022 at 06:15 PM.. |
I was hoping to remove ALL the factory sensors and switches, and utilize my Speedhut gauge and senders. One oil pressure, one oil temp. Programmable warning light based on readings. The dream was to put them both back by the breather. It'd likely work for the pressure, but I'm not so sure about the temp gauge - It wouldn't be submerged in oil, just kinda hanging out and occasionally getting splashed.
Early cars had the oil pressure sender back at the breather rather than off the oil feed for the Cam towers.
![]() There are some early senders that have both the pressure sender and switch in one. The 993 also had a combined function sending unit as well. I do not know what the speedhut sender looks like but you might be able to mount it in the rear like early cars. You would need to change your oil feed line to the cam tower as well.. john |
My gauge can't be configured for any old sensor, either - I have to use the ones they send with it, otherwise I'd get myself a 2-in-one temp/pressure. |
