Turbo Tie rod install - help!
I’ve got a 1971 911. Rebuilt the steering box and rest of front suspension. I also got the turbo tie rods on. I forgot to mark which old tie rod is for the drivers side and which is the passenger side so now I don’t know what to adjust the new ones to match.
Is the drivers side or passenger side the longer tie rod? Does anyone remember?
Thank you!!
Old 03-28-2022, 09:28 PM
Gonna have to start from scratch with new components.
Old 03-29-2022, 05:55 AM
Sorry, no help from me either, but look at the bright side, you have a 50/50 chance of getting it right.
JUAN
'80SC Targa
Old 03-29-2022, 06:25 AM
Administrator
Matt at Pelican Parts's Avatar
As far as i can gather from this old thread the consensus seems to be that they are identical
There is a section on the turbo tie rod install guide where they mention lining up the old one with the new one to adjust them accordingly, but there doesn't seem to be a mention of identifying the left from the right.
-Matt
Old 03-29-2022, 08:28 AM
Center the rack, use a tape measure, scribe a line in the tires and get it close to even at beer can height. Then take it in for an alignment.
Old 03-29-2022, 10:16 AM
917_Langheck's Avatar
https://www.youtube.com/watch?v=NB9va9D0GXI&list=PLAnoC5HB7uww48qLbnWJdjj94FV-CHumy&index=2
Around the 9:21 mark he illustrates the sides and respective measurements. But as Matt mentioned, they should be identical, and as 911obgyn mentioned, center the rack and rough set the toe, then either precise align, or take it to a shop.
Old 03-30-2022, 06:14 PM
