Excess oil in sump
2.7 1977 911
When draining the oil there was so much from the sump when all the info says the majority of the oil is in the tank. And as the oil tank will fill when the engine has been running can you tell me what stops the oil returning back into the sump when the engine is not running.
Is it that the clearances in the bearings are to small to allow the oil to drain back into the sump under gravity if so I may have to much clearance in the bearings?
Any help very welcome 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Old 06-09-2022, 09:22 AM
It slowly drains back through the oil pump gears.
Old 06-09-2022, 10:02 AM
Thanks for your reply
Does that explain why the oil level reads low on the gauge when you start the engine and rises after a time
Also do you know if the oil pumps are prone to wear
Thank you
Old 06-09-2022, 12:01 PM
Mark Salvetti's Avatar
I don't think the oil pumps are particularly prone to wear. Unless you have huge mileage on that car, it's probably OK. Are you thinking if the pump was worn it would be more likely to allow the oil to drain back?
Some cars just do that. Rothsport sells a check valve to prevent it.
I think the oil level being low at startup is more a function of temperature. The oil expands about 10% when it gets to operating temperature, which on a 911 means expansion adds over a quart in volume.
Mark
1979 911SC Targa
Old 06-09-2022, 01:30 PM
It's a 914 ...
stownsen914's Avatar
Equalizing of the oil level in the tank with that of the engine sump is a common issue on older 911s as dannobee noted. And yes the tank level will be measurably low when this happens. Unless your engine is leaking, or oil is getting somewhere you don't want it (it can get to the muffler in some cases and make a smoke bomb), don't worry about it.
Old 06-09-2022, 07:06 PM
Thank you
No.
The level on the gauge is useless, until the engine is warmed up to operating temps. Don't bother checking the oil level on the gauge, or the dipstick until the engine is warm, and at idle for 60 seconds on flat ground. Get the level between the two marks on the dipstick at that point. Don't fill the tank to the top mark, that is overfull.
Old 06-10-2022, 03:48 PM
ROW '78 911 Targa
timmy2's Avatar
Lots of oil in the sump if you don’t drain it while hot as recommended.
Hot oil change is what the published info is based on.
Drains back from the tank over time.
When hot, lots come from the tank, not so much from the sump.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-10-2022, 06:42 PM
DerkPerk's Avatar
So if the oil drains back to the sump, and you can drain the sump during the oil change, why does it need to be hot?
Old 06-10-2022, 08:47 PM
Hot oil changes are always good because theoretically there could be things in the oil that settle when cold but come out of the drain plug more easily when hot. On the new 911s it’s important to drain hot otherwise it will take forever to do a proper oil change.
it's not leaking....it's just marking it's territory
Old 06-10-2022, 09:04 PM
Alan L's Avatar
You should always drain oil hot. Never cold unless there is some compulsory reason - failed engine that needs to come out. Cold oil is like treacle. You will leave a whole lot behind and any gunk that is stuck to it. it doesn't need to be full temp, but very warm is a lot better than cold.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-11-2022, 01:05 AM
DerkPerk's Avatar
Excess oil in sump
I fully understand changing warm oil is better, and following that practice in all my vehicles. Jeep, truck, DD, air and water cooled P-cars. I was more curious on the topic of why the oil migrating from the tank to sump once cool and if it gets trapped in the motor somewhere of cool.
Old 06-11-2022, 05:05 AM
There is actually a lot of oil trapped inside the oil lines and engine nooks and crannies. The capacity is what, 12.5 quarts? But an oil change typically only requires 10 quarts to refill.
Mark
1979 911SC Targa
Old 06-11-2022, 08:45 AM
Alan L's Avatar
Yes - for a 911 there is only a partial oil change. Unless you want to drain the lines at the thermostat.
But the oil tank is the highest part in the system, so at rest some oil is always going to drain to the lowest point - crankcase. Longer been sitting, more in crankcase. Something to remember if you suddenly decide to set the valve clearances. The exhaust valve covers will almost certainly be holding back a small tide of oil. You can lift that side of the car to avoid being swamped, or run it for a couple of minutes to pump some out, without the engine getting warm, or better, both. Or drain the stuff in the crankcase first.
Alan
Old 06-11-2022, 01:36 PM
