Help identifying two wires
The car is a 1976 RHD Targa. RSR Replica.
Can someone help identify the 2 wires in the picture below please? I thought they were for the license plate lights but they don't have power when the lights are on.
Oil Level Sender?
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
No, oil sender wires are connected and gauge is operational already
ROW '78 911 Targa
Rear fog lamp? But usually left side looking from back of the car.
Normally two sets come out , right side is oil level and license lamps. Left side is rear fog lamp and license lamp. Maybe some wiring changes were made during the RSR changes.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 05-01-2022 at 11:18 PM.. |
I can't see any obvious modifications to the wiring. I will test them again and check all the fuses
(man/dude)
Do you have license plate lights on the underside of the decklid? Those are the wires that used to go through the rear bumper guard to the plates light. I think they might have their own fuse. They'd hopefully be diconnected but if your car is backdated they may as well be removed.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
ROW '78 911 Targa
One should go to ground. The other should have power with light switch on if for the license plate lamps mounted on the bumper rubber.
Thanks for the help
If they are on their own fuse, then that could explain why no power when I had the lights on. i will double check all fuses The car hasn't been backdates ![]()
ROW '78 911 Targa
2nd fuse from the headlights. Grey wire.
(man/dude)
Well it's certainly been renovated! Looks great.
Those wires will come in handy if you want to install license plate lights like the factory did:
Heck, I’m only 5 not 71!
I have to ask, do you own that repair shop or are you just using the facility. I see a lot of Porsches and parts in different stages of disassembly.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Are the wires colored or coated? Weird to see a pair of brown wires. From the photo they almost look like household speaker wire.
1982 911SC |
ROW '78 911 Targa
Normal for 74 and newer. Porsche started using high temp cloth insulated wiring for the license lamps and to the oil level sender/rear fog lamp.
Neat, thanks. Did they do this for under-deck maintenance lights as well?
1982 911SC |
ROW '78 911 Targa
No, those are the only ones I'm aware of. Likely due to heat at the rear bumper.
Yes the engine lid lamp, but it wouldn't make sense for those wires to be routed down where shown.
1982 911SC |
![]() Looks like the fuse is not even powered, see the yellow arrow. I might just wire the plate lights from the rear park lights. |
Getting the wheels on it tomorrow. Tyres are 235 fronts and 295 backs
