1971 911 engine number question.
Hi!
I bought a 1971 911 T targa with a 1970 E motor in it. Now I'm thinking of putting the E engine in a 914 i bought and try to find a engine for the targa with at least the right engine code. Im new to this and wonder who can help me with figuring out what's the correct engine number for my car and what engine code it should have. I don't have any hope finding the right engine but it would be nice to come close. Chassie number is 9111111094. Thanks Peter |
Hi Peter, this will provide the beginning of an idea.
https://www.stuttcars.com/porsche-911-engine-numbers-1965-1989/ For more exact information, any "decent" 911 book (red book, author peter morgan, author brett johnson, porsche TSB, workshop manual, etc), will provide a better match, by first decoding your exact vin (i.e then choosing the engine type number to match). Without checking a book, at first possible glance I would says yours is a 1971 (model year) 911 US targa....sporto maybe (a lot of 1's lol). Im sure someone will come along and decode your VIN properly for you shortly. Once you know the "location" of the chassis and if targa and/or manual or sporto....then it is easy to determine the engine type number which would match that location (i.e a US, and ROW (rest of world) generally have engine type numbers. Once you have you determined your engine type number....then you can purchase one of those, ideally with a serial to match the "range" for the chassis/type/location. p.s. welcome to the forum! Last edited by strictly; 05-03-2022 at 03:38 PM.. |
My car's vin is about 80 ahead of yours - engine number is 6115530, type 911/07. So my guess is that you should look for case number somewhere around 6115610
Thanks, i forgot to mention its a Targa and im in Europe. 901 dogleg trans. Car was imported from Germany in early 80’s to Sweden.
Peter, what’s the engine number of the engine that’s currently in the car?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Its 6201766.
No reverse gear in life
Hi Peter,
I have 6115538 911/07 complete engine and matching gearbox that I pulled out of the matching numbers car (9111121235) to build a 73 RSR hotrod that now has a 3.0 liter high butterfly MFI RSR engine... The engine is in NL with the company restoring the car if you are interested in that - PM me. Cheers David
David Alstadter - There is no reverse gear in life!!! 74 911 2.7 Carrera 9114400120 - licht grün 71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI) 73 911S 9113301270 - silber metallic (sold) 72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold) Last edited by dwa917; 05-04-2022 at 08:58 AM.. |
gearhead
I’ve got 7638. I also have a crank and rods if needed…
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/966354-fs-71t-engine-911-07-bare-case.html
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Hi, what crank is it? A 2.7?
gearhead
Nope, just a regular non-counterbalanced 2.2 T crank.
