Idle drops at closed throttle
I have a 964 engine whose idle hunts just for a second on startup. I can deal with that. But, when you rev the engine and let the throttle go back on its own, the rpm drops to a low value and sometimes it would stall before correcting itself.
I have checked: 1. Fuel mixture using a air-fuel meter and the mixture is 14.x ish, pretty much OK 2. a vacuum check and there is no vacuum leak with a smoke test 3. Checked the functionality of the idle switch and the resistance changes from zero ohms to infinite when I move the throttle by hand (between 2 of the 3 pins) 4. There is sufficient free play in the throttle cable such that it is not binding when throttle pedal is released 5. O2 sensor is new. What else could I do?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
It's a 914 ...
I have a friend who has a similar issue with a 3.6 in a 914. He's told that it can happen with a light flywheel as it confuses the Motronic. (To be clear, any early flywheel is a "light flywheel" on a 3.6.) Let's see if anyone else can give input on that, clearly it's been done many times successfully.
Sounds like a faulty idle control valve?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Been here a while
I have exactly this problem with the 3.6 in my SC. It’s maddening. I’ve upgraded to the latest Steve Wong chip, checked for a little slack in the throttle cable, checked the idle control valve.
The engine needs a little damper to slow the closing of the throttle for the last few degrees. My balky shifter means that beteeen shift my car will stall. Makes me nuts.
looking for 1972 911t motor XR584, S/N 6121622 |
