Should I change my shocks?
Hi all,
My '84 targa has about 113k miles on it and I have no reason to believe that the shocks have ever been changed. They are green (Bilstein) on all four corners. I've done 3 DE's so far this year and have been thinking about upgrading my torsion bars now that I might be able to tell how the change affected the handling. Although I don't have any obvious reason (except mileage) to change the shocks, I'm thinking about changing those as well. Should I bother? I think the car handles OK, but I don't really know what OK is. Everyone else who has driven the car seems to have disliked the long throw shifting to the point that I can't seem to get a good read on anything else. And, at the DE's I've been to so far, it seems like everyone else is either driving a much newer car or one that is decked out for racing. Hopefully I'll run into someone with some driving experience in a stock car of this age at an upcoming event and get some good feedback there as well.
Thanks.
Tom Dickinson
1984 Carrera Targa, Black
Old 05-21-2003, 01:25 PM
Senior Member
Superman's Avatar
While Bilsteins are known for their longevity, I suspect your shocks are not working as well as they did nineteen years ago. And if you install stiffer torsion bars, you will be well advised to upgrade yoru shocks to match. Stiffer torsion bars store a great deal of energy and release it quickly. Even when new, your stock shocks would be outgunned by stiffer torsion bars.
Mocha 1978 911SC. "Coco"
Old 05-21-2003, 01:41 PM
Glasgow 911SC's Avatar
Believe me. If your shocks are that old you should change them if you have the $$$. I recently replaced my (probably original) rear shocks with Koni adjustables (fronts to be changed soon). I've not had the care alligned yet and the ride height is about 1.5"s too high but...the handling is night & day to what it was before.
I think it's easy to get used to what you have and you only realise the difference when something drastic changes. I would go for it before T-bar mods!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-21-2003, 03:12 PM
Cool. I was mainly thinking of doing both torsion bars and shocks (and maybe turbo tie rods) all at once so I could get the car aligned and balanced all at once. But it would be nice to see how each change affected the handling.
Chris...have you adjusted your Koni adjustables yet? They sound cool, I'm just wondering how much people take advantage of the adjusting feature. Is it a quick and easy change? Would a person need adjustables in all four corners to really take advantage of it? I'm afraid I'd just leave it stiff unless it was a fairly quick change. And at that point why pay extra for a feature you don't use. Unless Konis are still better that Bilstien Sports, not that I think I could tell the difference. I think I'd need to swap out my Bilstien struts for Konis if I went that route.
Tom Dickinson
Old 05-21-2003, 03:41 PM
Change your shocks/struts!! I recently did the shocks and struts on my '88 and they seemed ok to me before, but when I started pulling them out I found out that they were completely shot. It made a huge difference having the new parts in place.
Old 05-21-2003, 03:45 PM
I would stick with the Bilsteins, personally. You can get the new inserts. To replace the whole strut in the front is much more expensive.
Old 05-21-2003, 03:48 PM
ted ted is offline
likes to left foot brake.
ted's Avatar
If you are going to stiffer T bars don't settle for stock Bilstien sport shocks.
I had the yellow shocks with 30/21 t bars.
I recently got some revalved Bilstien shocks that made for a huge improvement.
Got mine at Mirage International in San Diego.
1 858 581 1101.
tell'm long Mike sent ya.
hint..
The stiffer t bars like a little more rebound control.
Old 05-21-2003, 03:50 PM
Senior Member
Superman's Avatar
Like I've said, Konis are awesome shocks, but it would be difficult...very difficult, to convince me that they are better than Bilsteins.
Doesn't Bilstein now make an adjustable Sport shock?
Old 05-21-2003, 03:55 PM
Driving member
jester911's Avatar
Well my car only has 70k on it and the shocks/struts were toast.
Just got new bilstein sports, new wheel bearings, front end alignment and wow what a difference.
Like masraum I thought the car felt pretty good before but now it is awesome. I could feel the difference immediately.
Do it. You will love it.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-21-2003, 04:26 PM
HarryD's Avatar
Re: Should I change my shocks?
Originally posted by tommyd
Hi all,
Thanks.
Hi Tom,
If you are upgrading your t-bars, you definately need to look at your shocks. You may need to go to ones with different valve rates. If it was me, I would be talking to a Porsche Speed shop for advice. There is a local fellow near me who is very knowledgable and would be able to help you sort it all out.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-21-2003, 07:14 PM
HarryD's Avatar
I had heard that sports in rear and HDs in front was a great combo for our cars.
Harry
2020 MB E350 4Matic
Old 05-21-2003, 07:17 PM
Thanks everyone for the advice. After looking though your comments and searching through past posts, I will upgrade them both at the same time.
The only non-stock thing about my car is that it has been lowered a bunch. Does any one have experience with Bilstein RSR struts that are suppose to help reduce bump steer issues with lowered cars?
I figure if I'm going to do all this, I might has well just do it only once.
Tom Dickinson
Old 05-22-2003, 08:51 AM
jyl jyl is online now
jyl's Avatar
HarryD . . .
Sorry to hi-jack the thread, but . . .
HarryD, I note your moniker has changed from "unemployed" to "reemployed". Are congratulations in order, or would you prefer condolences as this means less time with the car? Details?
Old 05-22-2003, 08:56 AM
I may have mentioned this before, but here goes...
Both Bilstein and Koni are very good brand names.
If your car had Bilsteins, then you can with them again and not have to readjust ride height. You will most likely require ride height adjustment as you move from Boge to high pressure gas shocks like Bilsteins.
I had Boges originally, and went to adjustable ( for rebound) Konis...low pressure gas fronts ( not requiring ride height adjustment...or at least easily done if required)...and fully huydraulic rears, also adjustable. These special part number rears are also about 2" shorter in body length..making them ideal for later car lowering and it won't bring the working guts out of shock travel range. Both front and rears are adjustable via removable knob on the shock top...so you don't have to take the shock apart ( from one end of the mounts) to adjust like other Koni's.
Altogether ...a nice set up, and the additonal rebound adjustment can also be used for ( later) larger torsion bars....if you go that way later.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-22-2003, 09:18 AM
Senior Member
Superman's Avatar
Does Bilstein make an adjustable sport shock?
Old 05-22-2003, 09:27 AM
91C2wrencher's Avatar
I was recently searching for shocks/struts and the Bilstien web site is a mess! they seem to be in the middle of a website upgrade, which to you and me means some of the links don't work. FWIW I've got Bilstiens on my '91 and love'm.
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 05-22-2003, 09:43 AM
HarryD's Avatar
Re: HarryD . . . Yep Got a JOB!
Well, I guess it depends.... I have a nw job with the State but I lost my free time to mess with my car. So overall it's ok.
Probably the biggest short term disappointment is I will be unable to do the top end rebuild myself. I will need to pay my wrench for the labor as I do not want my car in pieces for the 3 -6 months it would take me (while I am working for the man) vs the 1 month I was planning.
Thanks for noticing
Harry
2020 MB E350 4Matic
Old 05-22-2003, 10:01 AM
Harry, awesome, congrats!!
Old 05-22-2003, 10:12 AM
HarryD's Avatar
Steve,
Thanks. I used to live in Clear Lake and work for HL&P. How about you.
I don't miss the weather but do miss the good folks I met there.
Take care.
Harry
2020 MB E350 4Matic
Old 05-22-2003, 10:29 AM
Jamie79SC's Avatar
Bump super's question - anyone know if there's an adjustible Bilstein?
Jamie79SC
Old 05-22-2003, 02:22 PM
