Classic retrofit fuse box (mini fuses)
I just bought one of these from Audette and I don’t think it’s working properly.
Bottom line, the LEDs never light up. It there a re-set or something that needs to be done to get them to work. I’ve seen videos where they light up when you turn on the directions or have blown fuses…I get none of that. The panel is working as everything in the car works. Help (I have emailed Audette for info, nothing yet). |
Slow old car
There is a switch on the fuse panel that you need to move to turn it to ‘test’ mode, I’m assuming you’ve found that though yeah?
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
Mike - I have not seen the ‘test mode’ switch, where is it?
Kroon Wire Harnesses
I don't think the fuseboxes John is selling are the Classic Retrofit ones ?
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
If it is, in fact, a Classic Retrofit panel, aren't the LEDs fuse *failure* indicators?
If you pull a fuse (emulating a blown fuse / opening the circuit), does the corresponding LED light up?
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
The Audette fuse box has a two-color (red/green) LED below the fuse. Quote:
Classic Retrofit: ![]() Audette:
'77 S with '78 930 power and a few other things. |
Slow old car
In the pic right above, see the bottom left corner, that little red piece next to the bottom post for the left-most fuse is a switch that turns on test mode
Mike - that’s it, now it works.
Thank you. |
SFR, you were happy with the installation ? tight fit for multiple cables or everything went smoothly ?
I was happy with the install; yea some of the wires were tight, but overall it was fine.
