MSD too 123 dizzy
On the back of the MSD Box it says connect the white wire too the yellow 😳 I seem to have every colour other than yellow, how do I connect the MSD too the123 dizzy and what wires do I still keep
Old 05-28-2022, 04:52 AM
47silver's Avatar
https://123ignitionusa.com/wiring-diagrams/
Old 05-28-2022, 06:44 AM
Scroll down to the last picture on this page
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 05-28-2022, 06:45 AM
You guys are fantastic, thank you so much
Old 05-28-2022, 07:07 AM
ROW '78 911 Targa
timmy2's Avatar
Does this help? It is for a Bosch 6 pin CDI and the SC Bluetooth 123 distributor, but you should be able to figure it out for the MSD based on the wire designations if that is what you have.
Can’t tell from the picture, on what you have, not a lot of information in your post.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-28-2022, 07:09 AM
If you have a 123 dizzy for the 6 pin CDI , it will only work with that 6 pin CDI system.
If you have the 123 dizzy for the 3 pin, that one will work with the MSD box , and 3pin CDI, or coil only.
Ian
Old 05-29-2022, 04:19 AM
ROW '78 911 Targa
timmy2's Avatar
Ian
Just wired up an MSD Streetfire to replace a 6 pin Bosch unit to a 123 distributor made for the 3.0 SC with6 pin CDI.
So your first statement above is in need of clarity as it could be read as one cannot use an MSD on the 6 pin CDI model of 123.
You need to use the appropriate CDI signal input and wiring designations for each type of 123 distributor when using an MSD CDI would be a better statement.
The OP is not being clear about what he has or is using.
Playing a guessing game…..
Dennis
Old 05-29-2022, 07:39 PM
Schulisco's Avatar
I have an approx. 5years old 123 dizzy with a "Big Fat Spark" ignition booster module on my SC. I replaced a 6pin CDI box and the old dizzy. The BFS is an transistor operated ignition booster with an own tachometer output working perfectly together with the 123.
See the web page for the wiring diagram: http://big-fat-spark.com/bfs-eng.html => "diagram" => "negative earth".
It's almost plug'n'play compared to the original Porsche CDI diagram...OK, it's not exactly the same than a CDI box, but it works pretty well. With the tune version I have, I can use two separate ignition advance curves choosable by switch. one for "Super" (95ROZ / 90AON) fuel here, the other for higher octaned fuels like "Super Plus" (98ROZ/93AON) or even higher "Ultimate 102" (102ROZ/95AON)...needs to be tested on a dyno to be sure that you won't damage your engine...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 05-30-2022, 07:52 AM
I am using a 123 dizzy for SC that was running with 6 pin CDI. CDI failed so switching to MSD 6AL. Tried connecting to the Mag input of MSD from 123 SC Dizzy but seems to be out of phase timing way off. Do I need to used the white wire input of the MSD? Can you share how you connected the 123 SC Dizzy to the MSD?
Yarko
Old 09-09-2024, 02:32 PM
PCA Member since 1988
Another option is to drop the CDI/MSD box and run straight from the 123 to a coil. You'll need a coil with 1-3 ohms primary resistance and several K Ohms secondary (most of them are around 8K Ohms). Most of the MSD coils meet these numbers. One less thing to go wrong.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-09-2024, 04:07 PM
ROW '78 911 Targa
timmy2's Avatar
Yarko
Wired as above photo using MSD purple and green wires to the brown and green of the 123.
Did you put the MSD into 6 cylinder mode by cutting one of the small blue or red wires?
Dennis
Old 09-10-2024, 11:15 AM
Yes, MSD blue wire cut to put in 6 cyl mode.
MSD wiring:
Blue wire loop cut - to put in 6 cyl mode
Red wire loop uncut - for 6 cyl mode
White wire was removed from the harness.
Heavy RED to Battery
Heavy BLACK to chassis ground behind relay panel
Small red to ignition on at relay panel
MSD Gray to vehicle blk/violet for tach (this has been tested and works)
MSD Purple to 123 Brown
MSD green to 123 Green
Nothing, no spark.
Will check with a scope to see if there is a signal on the brown wire relative to purple.
I'm concerned that in this 123 SC dizzy the brown wire is tied internally to gnd so no signal.
Awaiting response from 123igntion support to verify.
When I connect
MSD violet to 123 green
MSD green to 123 brown
I get a spark however the timing is way off.
When this happens with a bosch SC dizzy tied to MSD we swap the violet and purple and it works fine to MSD. Doesn't seem to be the case with 123 SC dizzy.....
Anyone else have similar experience or have it working?
Yarko
Old 09-10-2024, 12:37 PM
