ReFuze from CDD Autogear
Thought I would give a shout out to the ReFuze product from CDD Autogear. Don't normally do endorsements but Alan provide top notch customer service when a small part was missing from my order and the product is worth the spend.
Product is well built, easy to install and arrived in a timely manor. I have a 71 911. I didn't follow the online directions as the process seemed pretty straight forward. I do recommend taking a couple before photos to reference and use the zip ties to bundle wire groupings to make it easier.
Took me about 2 hours for all three blocks. I found several wires during the process that needed to be cleaned up, and soldered a few off the groupings to make sure they connections were solid.
https://www.cddautogear.com/refuze-products/refuze-1970-1973
Old 06-04-2022, 04:04 PM
Agreed. Great product, well built, looks great, works great. Had zero issue other than the mounting screw for the blocks were not correct thread for '69.
I let Alan know, and he asked me to figure out the correct screw length and thread and said he was going to make sure to change it going forward.
Old 06-04-2022, 06:32 PM
Great products from ReFuze. Bought their 3-fuse block for the rear, and it was perfect.
Paul
1987 Carrera coupe
Old 06-05-2022, 04:49 PM
