Engine temperature too high?
My stock 1974 2.7L runs about 180-200 during regular driving. Pushing it a bit It goes to 220 and stays there. Should I be looking at getting an oil cooler or are these temperatures ok?
I just did a complete rebuild about 2000 miles ago and the only thing that was done out of the ordinary was flycut the heads to boost compression a bit. My engine hasen't got any oil cooler other than the one inside the engine .
1974 911 2.7L coupe with sunroof
Old 05-26-2003, 08:04 AM
Crusty Conservative
silverc4s's Avatar
200 to 220 is the operating range for the 911 engine. If it does not go above 220, you need not worry. 240 to 250 is too hot - at these temps, dimensions can change enough to cause problems, and regular oils start to break down, losing lubrication properties, causing more heat, etc...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 05-26-2003, 08:33 AM
reesestewww's Avatar
my car got to 280 once at Sebring in the summer. It happened real fast. had one oil coller then. added another and increased ventalation. no damage was done. i think i owe that to mobile 1. it n ow doesn't get above 190. i promised the car i would never run it that hot again.
Past:
04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne
Old 05-26-2003, 10:30 AM
Reese,
Your pic put a big smile on my face, Your ride looks awsome
Cheers
Old 05-26-2003, 10:46 AM
Crusty Conservative
silverc4s's Avatar
Reese,
Nice looking racecar.... Glad it survived the high fever & associated trauma..
BTW, it' s always good to remember that the oil temp reading is only at ONE spot in the engine, and not necessarily the highest temp area (think bottom of piston, inside of rod bearing, etc... )...
PS: I just returned from Wal-Mart, where they have Mobil 1 in the 5 QT bottles for $18.88 each. Looked like a huge stocking here...
Bill
Old 05-26-2003, 11:44 AM
nestorjw's Avatar
Send a message via AIM to nestorjw
Speaking of how hot it runs, I have an 83 SC and it doesnt have the temperature in degrees, just the bars. Where is the normal range for it to run?
Jeff
83 SC, Guards Red.
Old 05-26-2003, 01:16 PM
i changed the temp gage to the one w/ numbers and also changed the temp sensor to give an accurate reading. but i would say your gage should not go over half way to stay with in the normal opperating range. I would reccomend the gage upgrade, well worth it.
R
Past:
Old 05-26-2003, 04:22 PM
