Jcon's Avatar
Leaking Windshield - Drain Hole Question
My windshield leaks in the lower right hand corner (Drivers Side). Here's the question. Is it ok for water to get into the windshield channels. I mean is it expected and are there drain holes in there that could be plugged?
I did seal the windsheild rubber seal contact point with silicon all around the entire windshield on Friday. It slowed the water down, but did not stop it.
I can get a new windshield gasket / seal from pelican for $50 am I just better off replacing the old one ratherthan trying to find the leak?
Any thoughts
Jeff C
Jeff C
76 912E 2.6L
Old 05-25-2003, 05:17 PM
No it is not ok. There is no windshield drain. When you put the new gasket in you are supposed to seal both sides of the gasket with sealer. I think it is a urathane.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-25-2003, 06:41 PM
Send a message via Yahoo to FRED/LI
These seals are notorious for mysterious leaks. Have it replaced by a knowledgeable shop. Yes it should be sealed upon installation.
My former 84 would actually allow the water from a rainshower to visibly enter at the center of the dash at speed. They shrink over the years.......
Fred '95 Carrera2. Previous: '69S, '79SC, '84Carrera, '90 C2, 20+ years and counting......
Old 05-26-2003, 04:35 AM
Do _not_ use a urethane sealer on a 911 windshield gasket. Those are windshield glues, not sealers, and are intended for modern windshields that need to be glued in place for the passenger-side airbag to deploy properly. What you want is 3M Window Weld.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-26-2003, 05:43 AM
