Piston Type/Size/Compression?
I bought the car a few months ago and decided to scope it for future refernace as i modify it. Has anyone seen these pistons before? They look factory. They all leakdown test under 2%. I haven't seen any with these kind of gouge looking reliefs. Took me off gaurd for valve contact initially. They all look the same way. Car runs great. USA Car.
1982 911 SC.
SSI Heat Exchangers, Scart Sport Muffler, Weber IDA40 Carbs, ITG Filters. These are the only modifications that I'm aware of.
Old 06-14-2022, 02:12 AM
Old 06-14-2022, 02:27 AM
New-ish 911SC Targa Owner
pampadori's Avatar
what is the engine number stamped in the case where the green arrow is pointing at in the below picture?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 06-14-2022, 02:03 PM
64C0772. It's definitely been rebuilt/refreshed before looking at the seals and underneath the car. All of it looks almost new. Those pistons don't look like US low comp spec to me?
Old 06-14-2022, 03:44 PM
?max moritz?
Old 06-14-2022, 03:54 PM
Originally Posted by chiroracer View Post
?max moritz?
don't think so - max Moritz are wedge shaped with more angular valve cutouts -- see, e.g. https://www.fvd.net/adbimage/97149/shop_detail/10010303200_1.jpg
These look stock (or like these, that are represented as stock) to me -- https://www.ebay.com/itm/224884721742?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=224884721742&targetid=1645685073248&device=c&mktype=&googleloc=9028775&poi=&campaignid=16730423415&mkgroupid=135815925780&rlsatarget=pla-1645685073248&abcId=9300841&merchantid=6296724&gclid=EAIaIQobChMIzc2H3oyu-AIVxTY4Ch0uJQm4EAQYBSABEgJ-v_D_BwE
Old 06-14-2022, 04:30 PM
Looks like a standard CIS piston to me.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 06-15-2022, 02:32 PM
Thanks for the replies everyone. The pic linked/attached is the closest that I've found. None I've seen have this valve relief that I have in mine. I suspect a higher compression 9.8:1 euro piston at maybe a larger 98+mm bore necessitating the need for this relief?
Old 06-15-2022, 04:09 PM
pampadori's Avatar
I don't see a valve relief in your bore scope images. I think it's an illusion and you have standard cis slugs.
Take it apart and find out! ;P
Old 06-16-2022, 05:14 PM
It's a 914 ...
stownsen914's Avatar
I think the shadows in your borescope pics are playing tricks on the eyes. I agree that the piston in your pics matches CIS pistons. Not sure anyone bothered to make high performance versions of those things anyway.
Old 06-16-2022, 06:09 PM
95L67 Mahle casting number inside piston is standard US compression of 9.3 on a 80/83 SC
Bruce
Old 06-17-2022, 02:16 AM
