Journalist
AdamKaz's Avatar
Good crank, no spark – Anything left but ECM?
Hello braintrust. I’m trying to diagnose a no spark condition on an ’88 Carrera and am hoping I’ve forgotten or overlooked something.
I was idling at a stoplight when the engine suddenly turned off. No cough, no sputter, just off. Once towed home, I found no spark at the plugs. So here’s what I’ve checked in order:
• Tried a brand new DME relay from our host (no change)
• Found plenty of fuel in the fuel rail (just in case)
• Removed distributor cap and cleaned the copper points and rotor head (no change)
• Checked for spark coming from distributor input wire (no spark)
• Tested the coil for incoming power and internal resistance (12v and 7 ohms)
• Removed and cleaned the 11th fuse in the frunk (no change)
• Tested spark plug wires for resistance (1 ohm)
• Checked resistance on crank reference sensor terminals (97ohms on 1&2, 9,600 ohms on 1&3)
• Had the engine rotated while I looked for the crank reference pin through the transmission porthole. I didn’t see it, nor did I see a hole for one. Chalk that up to user error
• Visually checked all three DME grounding locations and all were still tight and solid
Is there anything I’m forgetting before I try a loaner ECM? The Bentley manual says the crank reference sensor resistance should be >100,000 ohms, and I’m getting .96 on my 200k ohms voltmeter. But I get the same .96 when I try the speed sensor resistance, so I also think that’s user error.
"The Rain" 1988 911 Carrera Coupe
"The Dog" 1970 BMW 2002
"The Saint" 2012 BMW G650 GS Sertao
Old 05-10-2022, 01:20 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
If there is no fuel pulses and no spark it could be FW sensors. If you have fuel pulses (strong smell of fuel at the tail pipe after prolonged cranking) but no spark this points to the DME itself.
The best way to check for fuel pulses is with an LED test light or NOID kit on one of the injector plugs. Testing for spark with an old spark plug grounded to the engine while cranking.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-10-2022, 01:53 PM
ischmitz's Avatar
The sensors both need to measure around 1000 Ohm (1kOhm). Assuming you reading is in kOhm 0.96 is a good value. Also check OL between shield and signal pin. And then some sensors measure OK and still turn out to be root cause. So ohming and finding a bad result is conclusive. But ohming them and finding the readings in spec is NOT conclusive. The best test is to check for fuel pulses and spark pulses while cranking. When both are absent 9 out of 10 times that's a bad sensor. Only in very rare cases the DME is at fault with that finding.
Old 05-10-2022, 01:59 PM
If that's the primary resistance, it's 10X to large. Hopefully it's not a silver coil.
Read here; 911 3.2 No-Start Troubleshooting
Dave
Old 05-10-2022, 04:01 PM
If you have a silver coil, buying a replacement is just a 505-50 odds crap shoot that the new one is any good. The old 35 year old black coil is usually a far batter coil.
If the flywheel sensors are original, replace them and the head temp sensor even if they test out fine. They will not live much longer anyway. It can be a bad connector or just a bad head temp sensor itself.
Old 05-11-2022, 06:22 AM
ischmitz's Avatar
The OP measured the resistance of sensors and the value seems to be OK. It’s not clear if this is a “silver coil issue”…
A quick test with an LED test light will reveal if the sensors are likely at fault (spark and fuel pulses absent) or not. Why not systematically diagnose rather than throw parts at it. And if the OP has access to a loaner ECU then by all means try that too rather than falling for the “check and rework the ECU“ scams that don’t fix anything and come back with “you must have had two problems and I only fixed one. Good luck”
Old 05-11-2022, 06:39 AM
No doubt just throwing parts at is is not a sane diagnostic method.
But if my 3.2 Carrera had the original 35+ year old flywheel sensors and I ever planned to drive it much (and I do) I would replace those sensors even if the car had just 20,000 miles and was a perfect concours car. Maybe that is just me. I have 185,000 miles on my 911 and those sensors have failed twice on me.
I will be doing another 3,500 mile road trip soon in my 85. I want it in ready to drive condition. The flywheel sensors live in a harsh environment. I prefer to KNOW they are fresh before driving 1,200 miles from home on a 10 day road trip.
Old 05-11-2022, 10:25 AM
Journalist
AdamKaz's Avatar
Thanks all.
Both flywheel sensors are <2 years old, so they are certainly not original.
What IS original (or at least very old) is the coil. It's black. I can't believe I never replaced it during my full restoration, but here we are... Anyway, it seems to be testing fine still.
Sounds like I need to source some noid lights before borrowing a ECU. I'll get on that asap and keep you posted.
Old 05-11-2022, 11:56 AM
proporsche's Avatar
keep the coil -black- most likely not your problem.
Do you have any alarm or immobiliser in your car.is my Q
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-11-2022, 02:27 PM
ischmitz's Avatar
To check if it's the power supply to the DME (aftermarket alarm or factory alarm triggered) simply verify the ICV is humming with the ignition key in ON position. If yes the DME is all powered up and waiting for flywheel signals to drive injectors, the coil, and the tachometer.
Old 05-11-2022, 02:32 PM
Journalist
AdamKaz's Avatar
Well the noid light was big fat 0. No response at all. I also removed my flywheel sensors from their bracket, wrapped them in cloth to prevent any grounding, and tried again - no difference.
I'll check the ICV (I haven't heard anything, but I'm generally playing music), but it sounds like we're zeroed in on the flywheel sensor?
Old 05-11-2022, 07:30 PM
ischmitz's Avatar
The NOID light has to be plugged in with the correct orientation to flash. Did you try both orientations? Not sure what you mean by “wrapping the sensors in cloth”. The sensor works perfectly fine when grounded to the transmission in its clamp. A short can happen inside the COAX cable. GND comes from the three pin connector.
Another useful test is to use a DVM in AC setting or better yet an oscilloscope and measure the output of the speed sensor and reference sensor while cranking. Best to measure inside the 35-pin connector (DME removed).
Old 05-11-2022, 07:40 PM
Plug and unplug the 14 pin connector check grounds.
Old 05-11-2022, 09:45 PM
Journalist
AdamKaz's Avatar
I was concerned the noid light might have a polarity, so yes I tried it both orientations.
I wrapped the sensor plugs (in the engine bay) away from their metal bracket because someone here suspected them might be grounding out. I don't have an oscilloscope, but I can try the voltmeter while cranking.
I've checked all ecu grounds, but haven't unplugged/replugged.
Old 05-12-2022, 08:01 AM
ischmitz's Avatar
Is the ICV humming with the ignition on?
Old 05-12-2022, 08:17 AM
Let's try again. Read here & follow the troubleshooting procedure;
Dave
Old 05-12-2022, 09:14 AM
Call 911
dkirk's Avatar
Had a similar problem with my '88 this Spring. Initial start after winter storage went well and test drive went perfectly. I then removed the Motronic ECU to install a new performance chip. Got it all back together and no-start. Could smell fuel but obviously no ignition. Removed ECU and swapped chips - still no-start. Swapped DME relay, still no go. Returned entire ECU with new chip to Steve Wong who did a diagnostic test and repair. He found problems on the digital circuit board which required re-soldering. These components are 34 years old and problems can occur just due to the age.
Dave Kirk
My Porsche restoreth my soul.
Old 05-12-2022, 02:03 PM
Not really! Most likely the circuit board was damaged (weakened solder connections) during the chip exchange, or during the logic board separation.
Dave
Old 05-12-2022, 06:06 PM
Journalist
AdamKaz's Avatar
I can confirm the ICV is humming when the ignition is on!
@mysocal911 - I read the post you're repeatedly suggesting before ever posting here (I know the search feature exists). I do not find it helpful.
Old 05-13-2022, 02:31 PM
ischmitz's Avatar
Adam, with that you know the DME gets power and only needs speed and reference pulses to release spark and fuel pulses.
Try to measure the outputs of the speed and reference sensors at the 35-pin connector while cranking. Set the DVM to V-AC and report back.
Further, do you have access to a loaner DME. That’s a quick way to either identify or rule out the DME itself.
I’m still wondering if maybe your NOID light test wasn’t conclusive. First have you confirmed +12V at the injectors and at the coil primaries with ignition on? Next, the pulses the NOID light emits are very faint and short, best do this after dark. And lastly, you can also use the NOID light across the coil primaries to check for ignition pulses.
Assuming your current findings are correct in that both fuel and spark signals are not issued by the DME the potential faults are:
(1) one of the flywheel sensor signals isn’t present
(2) flywheel decoder or logic gate controlling the flywheel decoder inside the DME are damaged.
9 out of 10 times it’s (1) but then you said the sensors are new. Still, it could be a quality issue with the replacement sensors. So don’t discount it. If it’s (2) a simple resolder will not fix that.
Old 05-13-2022, 02:48 PM
