Engine Type 930/01
I’m buying a motor and it has type 930/01 but no serial number. The Type number looks like a factory stamp to me but I can’t find any info in any of my reference books for this. Reputable race shop says 3.0L 964 cams and JE pistons. Can anyone help me with this?
67 Normale "Old Rusty"
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 12:37 PM
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 12:59 PM
917_Langheck's Avatar
What does the bottom of the case look like - early or late 930 case? How about the 930.xxx.xxx.xR case number?
____________________________
If it's not leaking, it's out of oel...
Old 07-01-2022, 01:28 PM
Early sump style case. No engine number. Looks like 3.2 heads. Standard short intake studs.
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 02:05 PM
Case part number 930.101.104
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 02:07 PM
Oops forgot the 4R. It doesn’t have the early style turbo casting numbers on the side of the case.
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 04:31 PM
Excellent Rick. Hopefully, someone will recognize the context and be able to give you a definitive answer. Looks like a good package.
Cheers
Old 07-01-2022, 04:57 PM
Thx for taking the time to take a look. It really doesn’t matter to much what it started as I’m just curious. I’ve never seen an 01.
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 07-01-2022, 05:01 PM
gearhead
On each side of the case there should be a small circle that contains a casting date. I’ll try to post a picture showing exactly where later. It may give you further info.
My best guess is a factory replacement case and someone just stamped it like that.
Old 07-02-2022, 06:50 AM
Does it have a 6 or 9 bolt crank?
Old 07-02-2022, 06:54 AM
