71 E won’t start
Hi Pelicans,
I got my rebuilt engine in and it won’t start. Smells like it’s getting plenty of fuel. Bought 2 new batteries yesterday. I checked the spark at the coil wire and I see a spark. Not sure how strong the spark should be. I can barely see a little spark. I cleaned both battery terminals and cleaned the wires and replaced connectors that go on the driver side terminal. It might be my imagination, but it seems like the lights under the hood are a little dim. I checked all connections and grounds in the engine compartment. Not sure where to go from here?
Mark
1971 911E targa
Priors:
1955 Speedster, 74 911 coupe, 69 911T coupe, 74 911 slant nose w/928 lights, 03 911 Turbo
Old 07-02-2022, 06:19 AM
Try timing
Old 07-02-2022, 06:34 AM
Originally Posted by Dpmulvan View Post
Try timing
Not sure how to check timing without it running
Mark
1971 911E targa
Priors:
Old 07-02-2022, 06:37 AM
Look up static timing a distributor. Basically you are lining up flywheel timing marks and distributor rotor marks by hand. You have to static time your distributor to get an initial time on your rebuild.Good luck. John
Old 07-02-2022, 06:46 AM
Thank you John,
I will give that a try
Mark
Mark
1971 911E targa
Priors:
Old 07-02-2022, 06:48 AM
How strong is the spark from the coil wire? I can barely see mine
Mark
1971 911E targa
Priors:
Old 07-02-2022, 01:59 PM
otto_kretschmer's Avatar
If you turn the lights off in your garage (assuming you have it in a garage) the spark should be bright blue and you should hear a distinct pop.
Did you use new plugs?
Old 07-02-2022, 02:28 PM
Lash
Was the rebuilt engine tested (ran) at the repair shop? If it ran at the shop than you can eliminate timing, coil. I would look at external problems such as weak battery voltage, CDI, gas.
Check your ground wires, need clean connections and tight.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 07-02-2022, 02:35 PM
Dave Kost's Avatar
Check that the points aren't closed.
Dave K
Old 07-03-2022, 01:56 PM
90% sure is will be timing or plug wires out of sequence - setting the timing plus or minus 5 deg the engine should start but it will never even fire if the plug wires are incorrect
Old 07-03-2022, 07:23 PM
Thank you all for the input
I did the static timing
Points are open to .004
Plug wire have been checked…the order going clockwise 1 6 2 4 3 5. #1 is at the notch on the distributor.
The rotor spins clockwise
I see this picture and it has the order counter clockwise?
Also bought 2 new batteries.
Car turned over well at first….not it barely turns….did I ruin the starter?
I did put oil in car before I did anything
Happy 4th to all!,
Mark
1971 911E targa
Priors:
Old 07-04-2022, 04:31 AM
Functionista
manbridge 74's Avatar
Points are to be set at 0.014 if working in inches.
Old 07-04-2022, 07:46 AM
I was in mm
Mark
1971 911E targa
Priors:
Old 07-04-2022, 07:56 AM
Check battery voltage at battery terminals, should be 12.4 V. Remove all spark plugs, are they wet? Clean with carb cleaner and compressed air. Reinstall. Disconnect cold start solenoid wire, remove aircleaner, Open throttle plates and put about a teaspoon of gas in each throat. Now crank engine, it should try and start, if it does but will not yet keep running turn it off and repeat priming process. As it tries to start it will eventually fill all the injector lines and keep running. Your lines are dry right now.
Old 07-04-2022, 08:40 PM
Hi Ed,
Thank you for the detailed response.
I can give it a shot.
Unfortunately right now the motor will barely turn over.
I bought 2 new batteries and the have 12.4 V each.
Do you think the starter has gone bad. It will turn the flywheel, but barely. Not strong enough to start the motor.
Mark
1971 911E targa
Priors:
Old 07-05-2022, 05:02 AM
Lash
Hi Ed,
If your new battery's are fully charged and starter is turning engine over slowly than you need to check battery cable to starter. The connection needs to be clean and tight. You can also have a corroded or dirty starter case where the starter fastens to the engine block. You need to have current flow from positive battery post through the starter, engine case, body frame and back to the negative battery post. That's why I mentioned checking the ground straps in earlier post. If grounds are good than your starter/solenoid may be the culprit.
Hope this helps
ps you never mentioned if engine was tested at the repair shop
Lash
Old 07-05-2022, 04:32 PM
Excellent point, since the engine trans have just been put back check that transmission ground strap. Assuming the starter cranked the engine before the overhaul there's no reason it shouldn't now. The fly in the ointment is if the rebuilt engine is 'tight' Only the builder will know that.
Old 07-05-2022, 05:44 PM
I think your points should be set to approx 0.355mm… .004mm is very small.
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 07-06-2022, 12:15 PM
Hope this helps
Thanks for all the suggestions. I checked all the grounds…trans to body, battery, starter to block.
The motor was never tested out of the car.
I towed it back to the mechanic that built the motor. As soon as I know what it is I’ll post it……unless I made a total bonehead move…then I’ll smoke screen. 🤣
Mark
1971 911E targa
Priors:
Old 07-06-2022, 01:03 PM
Lash
We like to here about bonehead moves. it makes the rest of us feel better.
Lash
Old 07-14-2022, 01:57 PM
