I use Onshape. It’s free unless you want to keep your designs private and all the work is done on their server so you can move from device to device and work on the same file. I started with it because I could not afford a capable computer. Excellent for collaboration as well- no files to send and or update and see the other users changes in real time.
Intake that transitions from the rectilinear AFM to a round filter in Onshape: http://forums.pelicanparts.com/uploa...1705893501.png |
Someone make simple manifolds to use with the stock runners for different carbs set ups. Lots of Webers types we are not using and the triple 40 IDA's are old.
Sent from my SM-G991U using Tapatalk |
According to the nice people at Bambu Labs, should be hear within a week.... I can hardly wait to see if my designs actually work, man o man, could I have used this 3D printing stuff to great benefit over the years. The whole idea of being able to custom design and print everything from the silly plastic bits that cost a fortune, to be able to customize them to making the one-time tools such as the seal installers. Fantastic.... D. PS - I am not a big poster on this forum....long story, but a very bad experience of someone close to me...but I will post the results of the complete story of the fan motor changeover in a separate thread. |
Manifold
I plan on printing a manifold in CF nylon for the weber carb. As soon as I get a new mother board and firmware in my printer, talking to each other nicely. I don't have the numbers in front of me right now, but the heat tolerance is close and should work. I will be using phenolic spacers as insurance to start with. After getting good temp numbers off the head and at the manifold, I may eliminate the phenolic spacers later.
http://forums.pelicanparts.com/uploa...1705977642.jpg http://forums.pelicanparts.com/uploa...1705977642.jpg See my thread for more details, https://forums.pelicanparts.com/porsche-911-technical-forum/744845-pendulum-outlaw-build-adventures-misadventures-19.html |
Addnorth has a material good to 180c (364f) CF reinforced PC. Jonte over on Rennlist is using it for some I’m exhaust related parts I believe on his 964 project.
https://addnorth.com/product/PC%20Blend%20HT%20LCF/PC%20Blend%20HT%20LCF%20-%201.75mm%20-%20500g%20-%20Black |
Interested in seeing how the manifold works for you, Tom Elder. The CF nylon I have used is amazing, but the surface I get is not totally smooth. Maybe that wouldn't matter in this application -- I have no idea what it would do to the mixture/flow.
I would be tempted to try nylon without CF for a smoother bore. I have some on order this week to test out. I would worry about distortion/embrittlement with heat cycles with any of these non-metallic materials in this application, but glad someone is trying. |
Have you tried vapor honing the surface? I believe with nylon you can simply place the object in a container above a pool of acetone, and let the vapors smooth out the surface.
Pete, thanks! for the post, I bought a roll of Carbon X PA12 CF which has a Heat Deflection of 150C HDT @ 0.45MPa (137c HDT @ 1.8MPa) The material you suggested PC HT LCF states “withstands temps up to 185c.” Which is a very nice step up in performance. Wish they qualify their statement with the test method. Also wish they had a stiffness value, long fibers are good for stiffness. It sounds good but I would like to see proper engineering data set. Hard to compare materials when you don’t know the test methods.
Torch, I have not printed CF PA at home yet, but for a short period of time, I had access to Desktop Metal FDM machine. The parts produce from that machine had a very nice surface finish. Which I think is acceptable for an intake manifold. Intake ports do not need to have a mirror finish, a bit of roughness is good so the fuel mist does not stick to the walls. Porting metal bores about 180 grit is supposed to be good. Before modifying my printer, it was good to print at 260c, just enough to print on the low end of nylon recommended print temp. From what I have read, printing PA CF on the high end of the recommended temp produces a stronger and smoother part. Which why I elected to attempt to modify my printer. Will post when I get there. |
The Bambu can go up to 300F. The PA-CF is really strong.
Here is PA-CF next to PLA. This is just stock settings, I haven't done anything to optimize the finish. The finish of the PA-CF is pretty darn smooth, just a little pebbly up close, not as smooth as PLA, but due to the higher temp, curves come out nice, layers are really bonded and invisible. Keep us updated. If you want to send me a file, I can try printing maybe a single port section just to see how it goes. The photos make the Nylon look much worse than it is in person -- just a lot of reflection on the pebbling. http://forums.pelicanparts.com/uploa...1706053400.jpg http://forums.pelicanparts.com/uploa...1706053400.jpg http://forums.pelicanparts.com/uploa...1706053400.jpg |
You guys with 3D printers are making me jealous. I may have to invest in another expensive/time suck hobby!
Ok, took delivery of the Bambu with AMS today.
Easy to set up, did two test prints....very nice. Fan mount is printing in PLA as we speak as a test, it's really very automatic and does most of the hard work by itself. I set auto-orient, clicked to add supports when in warned me that I was printing in mid air.....and off it went. Even takes a time lapse for you with its little internal camera just for fun. Had to tell someone, this printer is the cat's ass.....very nice.... D. |
Made some intake pipes for my 964 intake out of PAHT-CF. Wanted to test the strength. Put a 3.25" (82mm) diameter pipe with 3mm walls into my vice and cranked the daylights out of it. Compressed into an oval 1/2 the diameter without a crack, and when I took it out it rebounded close to the original shape with barely a mark on it.
Then I cranked it until it broke. At about 1.5" (40mm), it finally broke. Amazing stuff. http://forums.pelicanparts.com/uploa...1706281668.jpg http://forums.pelicanparts.com/uploa...1706281668.jpg http://forums.pelicanparts.com/uploa...1706281668.jpg http://forums.pelicanparts.com/uploa...1706281668.jpg |
Ok, print finished...got delayed as it ran out of PLA in the middle of the night and I have to learn how to tell the printer to use another roll that is already in the AMS.
Quite happy with the result, actual print time around 8 hours, finish is excellent. http://forums.pelicanparts.com/uploa...1706290709.jpg http://forums.pelicanparts.com/uploa...1706290754.jpg http://forums.pelicanparts.com/uploa...1706290754.jpg Doing the checks to make sure it all fits, housing looks perfect as does electrical blade holder. For sure two mistakes. 1. I only gave 0.1 mm clearance for the motor to slid in....too tight. Probably should give it 0.5 mm as right now I'd need a hammer to pound it in...not good. 2. Two of the three support arms are not fastened to the motor holder. I looked closely at the Fusion drawings and sure enough, there is a tiny space between the arms and the housing. The Combine feature did not actually make it into a single piece, not sure why. Next steps are to finish the checks, make adjustments to Fusion and then reprint. This one costs me $6.45 according to the Bambu and took almost 8 hours. Will post again when v2 comes out.... D. |
Torch, thanks for the offer to print one of my manifold flanges. I have the display, display firmware, mother board and main firmware all talking to each now and can print lower temp materials again. Installed a new temp thermistor yesterday but need to update the firmware again and then I will be able to print CF Nylon. Just waiting for Amazon to deliver a micro SD card extension cable. Small mistake on my part, forgot to cut a new SD card slot in the case before reassembling the printer.
I like your test, very encouraging, to see. Surface finish looks good. What brand of filament are you using. When printing PLA for prototyping, some of the cheaper brands are not worth the savings. I always find the quality brands just flow nice, layer adhesion is better. Keep us updated on your progress and discoveries, when printing with these better materials. Cloggie, very jealous of all the Bambu Labs printers showing up here. Congrats, let’s see parts! Ok, that was fast, just typing and you posted pictures! |
Well, doing the fit checks, I discovered for the four millionth time in my life I am an idiot. I reversed a measurement for the fan to motor distance, so the motor is sticking about 40 mm too far out, it needs to go inwards by a measurement I built in fusion as outwards. Sigh, but that is why we love rapid prototyping...right. So I am remeasuring, redrawing and will reprint as soon as I can...and post of course. Lesson for me is to make a hand sketch, put the dimensions on it and then get busy with Fusion. I just wrote down the dimensions with a descriptor and lo and behold, what ought to have been -20 mm or so, I made +20mm. Live and learn, but great fun! D. |
Sorry, I could not resist :) One thing to check when you have round parts combined with support arms is to make sure the arms go fully into the round body. Often the flat face of the support army only touches the round face at the very centerline of the support arm. This often happens when you use sweep. And can happen when you sketch to the round object and then extrude to that edge. The quick fix is to offset face the end of the support deeper into the round object. |
Tom,
I am using the Bambu filaments so far. Only had the printer for a week or so, so have stayed on the Bambu farm to get going. I have tried PETG-CF, and it was not as nice looking / more CF stranding than the stuff in my pictures, which is the PAHT-CF from Bambu. Cloggie: I find it's pretty easy to throw the whole stl into Bambu, then using the split function isolate the parts I am working on fitting. For example, the pipe bung is a bit complicated in mine as it's cutting a vertical threaded NPT hole in an angled pipe. Rather than print the whole pipe, I sliced along the Z and Y axes with some tilt to get rid of needing any support to print the bung only: then I check check the fit, see how the support removes, test fit the sensor, etc. Saves a lot of time and filament to check individual sections of the overall model for fitment. I have also found that draft or extra draft modes still make impressively accurate parts a little faster. |
I think Fusion has some sort of "fix" option, but I am not smart enough to make that work....not yet, maybe not ever. Oh yeah, I am using only Bambu stuff right now, when I feel like I have mastered this 3d printing thing, I will explore more....meantime, I will stay in the walled Bambu garden Thanks! D. |
| All times are GMT -8. The time now is 09:24 PM. |
