Magnesium fan-housing replacement
I had to replace the alternator and found out that the original magnesium fan-housing was badly cracked.
![]() Looking for a replacement I found the US-made EPS Al unit (weighing 11lbs) and a magnesium replica (weighing 2.73lb) made by CarPoint. ![]() The german unit shipped from Germany in 3 days at a cost (including shipping) of about 60% of the EPS part. The fitting is perfect, both fitting the engine and cooling shroud, as well as fitting either the Valeo or OEM 90A alternator. Carpoint sells in the USA on eBay. Link for the fan-housing Note: I must credit member Discseven for his excellent advice and guidance in making this repair! Last edited by adias; 08-10-2017 at 01:16 PM.. Reason: Added eBay link |
Burnin' Rubber
Where was this tip a few months back!!!
![]() Good to know! |
Wow glad you got it replaced, cause it would have been a catastrophic failure! Those cracks look really bad! I wish I would have found the German site you got yours, since I replaced mine years back with an aluminum one from Vertex. However, I can't complain much, it is a solid piece so I know it will be there for years to come. Anyway great work!
U.S. Army Retired 85 Targa Guards Red ![]() 2018 BMW 530i M-Sport ![]() Personal Quote: "Do whatever makes you feel good"
/ˈpɔrʃə/ PORSH-ə Fan
I found the Carrera 3.2 fan housing/shroud the hardest to find. I couldn't find an aluminum one at the time, but did find a new replacement magnesium unit. Happy to find it and it fits great.
I wasted a couple of days dragging my old housing around to welding shops to see if they would repair it. No one wanted anything to do with it. It's now wall art on my shelf.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
Vintage Owner
I understand that welding magnesium is a very specialized process, but can be done. I suspect most shops don't want to be bothered.
Was the housing dropped? I can't imagine there should be that much stress on that part as it only holds the ignition coil and fiberglass engine shroud attachments. I'd wonder if JB Weld would even suffice?
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
The 9 Store
Ben / MB911 welds alum, mag, steel, etc. he just fixed (rebuilt) the clutch cable bracket on my magnesium 915 trans. He has posts showing his welded and refinished fans and housings. He can fix the nicks on the fan for a fraction of new.
All used parts sold as is. |
The 9 Store
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Vintage Owner
👍 on Ben's talents! It's always good to find a true craftsman/artist.
Burnin' Rubber
I had my original welded by a great shop but it lasted a year. It is not worth welding repairs on this! It will fail and it's not a particularly pleasant job switching out the unit. Best to do it once, the right way, and be done with it.
It was a real pain finding a new unit. And it was not cheap either. Again, wish this info was available to me when I really needed it. Cheers |
does that German supplier have SC versions also or are they backwards compatible ?
that look like a very nice piece .
Just be sure the timing mark line etched on the new housing aligns with the split in the engine case.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Know fact that magnesium's stellar attribute is weight reduction. Cost for that is durability. Fractures in a fan housing can be beautifully repaired, but remainder of magnesium in that house is still age-stressed. Nice find & share Tony. And compliments on clean powerplant!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Functionista
The main reason they crack is people think the housing should be torqued to something like 100 ft lbs. I forget the spec but it's not a lot. Once overtightened they tend to crack or warp.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
eBay ad states "$102 shipping". Ouch! Glad it's light. :-)
Mark B '73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold) |
Right! Bentley states 18lb ft.
