I'm working on it....
MD540iT's Avatar
WUR....what does it really do?
Well at this stage in my Fuel issue saga....im starting to wonder what the point of the WUR is??
So I attmpeted to drive the car again, and all seems ok at first (running with the O2 disconected) its "driveable" but last time, I went to a friends house, and car was parked for a couple hours, came back and car barely starts and is barely idling, the A/F is 19-20+, Im thinking the WUR has heat soaked, so I enriched the mixture and drove home.
about an hour or 2 later I said, lets see what happens, So I try and move the pin(richen) the WUR... but it doesnt get any better. Then I swap WUR, with a "cold" one and see, sure enough it runs in the "normal" AF. Ok great....Next day I think its fixed and I can go for a drive up to the mtns. I drive and seems ok, I park for aboout 30 min, come back.....and guess what? A/F is way lean again!!!!
W T F!!!!!
So what if I take the "warm up" part out? I should be able to start it, and then set it. with out the WUR changing things. as it heats up.
Old 08-22-2022, 06:34 PM
GaryR's Avatar
Send a message via ICQ to GaryR
WUR, huh, yeah
What is it good for?
Absolutely nothing, uhh
War, huh, yeah
Absolutely nothing
Say it again, y'all
War, huh (good God)
Absolutely nothing, listen to me, oh
Sorry, had to.
Gary R.
Old 08-22-2022, 11:38 PM
Schulisco's Avatar
I guess a cold start will be impossible under several ambient temperatures and conditions.
The Warm Up Regulator manages the control pressure of the fuel distributor. FD is required to have a proper managed cp on all driving conditions. It depends on your car which WUR version is installed. Some have a vacuum connection to manage driving on higher altitudes to lean the mixture, some have an additional vacuum connection to manage load on the engine while accelerating to enrichen the mixture. They differ in the control pressure curves depending on the engine. Guess it's a lambda controlled SC? Which model year, which engine code?
When you disconnect O2 the ECU goes into the "limb home mode" with a fixed duty cycle of 50% for the pulse valve on cruise and idle. You'll loose power and buy addtional fuel consumption.
Check the WUR if you got the correct version for your car, let it overhaul and get happy with a nice startiing engine and a fuel efficient and performing car under any conditions.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 08-23-2022, 02:37 AM
MD540iT's Avatar
The Warum Up Regulator manages the control pressure of the fuel distributor. FD is required to have a proper managed cp on all driving conditions. It depends on your car which WUR version is installed. Some have a vacuum connection to manage driving on higher altitudes to lean the mixture, some have an additional vacuum connection to manage load on the engine while accelerating to enrichen the mixture. They differ in the control pressure curves depending on the engine. Guess it's a lambda controlled SC? Which model year, which engine code?
Thomas
this is a turbo, I have disconnected the vac/boost port. (because it goes to rich)
I have 3 WUR's if 2 of them both go rich after heat soak, despite being adjustbale.....
I just pulled the Bi-metallic strip out of the 3rd one and will try that
Old 08-23-2022, 02:46 PM
MD540iT's Avatar
Ok I just went and installed the WUR with out the "warm up" parts. initial pressure was 45. started normally. I tried to drop the pressure with the allen but it didnt drop any more. (I was able to raise it however)
SO next I took the bottom half of the WUR off so there was no spring/pin, just what ever it naturally would be at and that was 42 psi. didn't drive it or let it get hot, but might try that next.
Old 08-23-2022, 10:59 PM
Schulisco's Avatar
Which model year and engine code?
Old 08-23-2022, 11:38 PM
T77911S's Avatar
thats the WRONG thing to do.
when you have a problem dont go modifying things from how it was designed.
you want everything to spec.
the WUR does not really "regulate" as its name implies. it just changes the mixture, by changing control pressure, for cold starts and hot running and with the turbo making it richer under boost.
if you go too rich under boost it could something as simple as an air leak on the pressure side. or if you vent your BOV to atmosphere it could be opening when it shouldnt.
you HAVE to have gauges.
you need to know the cold pressure, hot pressure and pressure under boost.
you can buy a hand vac that will also pressurize the WUR to check control pressure under boost.
with all you have done to your WUR i would send it off and have it modified and set to spec.
you need to provide more info about your car
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-24-2022, 03:28 AM
T77911S's Avatar
i thought your problem sounded familiar from the 930 side.
good luck
RACE CAR:: sold
Old 08-24-2022, 03:33 AM
You really didnt have to. Now its stuck in my head.
Originally Posted by GaryR View Post
WUR, huh, yeah
War, huh, yeah
Absolutely nothing
Say it again, y'all
War, huh (good God)
Sorry, had to.
Old 08-24-2022, 05:34 AM
WUR Identification...........
MD,
What is the Bosch ID # (0-438-140-XYZ) on your WUR? You need to test and verify the settings of your WUR using a pressure gauge if they are still in specification. If they are out of spec, you need to recalibrate the settings in order for the WUR to work correctly. Keep us posted.
Tony
Old 08-24-2022, 05:42 AM
MD540iT's Avatar
Well, FWIW, it seems to run better with the "open" WUR and not being effected by heat soak.
Old 08-25-2022, 10:55 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Why have you decided the WUR is the problem in the first place?
I presume the allen screw you are adjusting is the one on the fuel distributor. If this is so, I think you need to take about three steps back, learn a lot more about how the system is supposed to work, then humbly start over under the guidance of the shop manuals, someone like Tony, or the CIS for dummies thread.
Willy-nilly adjustment and parts swapping is unlikely to lead to an optimal outcome.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 08-27-2022, 05:14 AM
CIS troubleshooting..........
Originally Posted by boyt911sc View Post
MD,
Tony
MD,
You are not doing the right way to troubleshoot your CIS problem/s. So far, all your WUR’s exhibit out of spec for control fuel pressures because you made the wrong adjustment procedures. If you would share with us the Bosch ID #’s of these WUR’s, people with experience could give you a meaningful advise. So far, you have been unresponsive to this request. Good luck.
Tony
Old 08-28-2022, 03:37 AM
No fuel pressure gauge and No AFR gauge.
I hope for you’re sake it’s too rich. Otherwise POP goes the engine.
Derrick
Old 08-28-2022, 05:52 PM
T77911S's Avatar
there is very little heat on the top of the 930 engine.
set the WUR to spec and find the REAL problem.
i spent probably 2 yrs, maybe more (off and on) trying to fix a very lean cruise condition.
i did a LOT of experimenting and testing with fuel pressure AND control pressure.
in the end i had a bad FD (cast iron) even after being rebuilt twice.
set it back to spec
make sure all the CP are correct. even under boost.
buy a hand vac that can also pressurize and check the WUR CP for boost.
make sure NO air leaks on the pressure side.
for me, even venting my BOV to atmosphere had an effect on AFR.
make sure system pressures are steady and good.
check fuel flow per spec to WUR and out of FD.
RACE CAR:: sold
Old 08-29-2022, 06:21 AM
MD540iT's Avatar
MD,
Tony
one of the WURs # is 0458140 (916)
Old 08-29-2022, 11:33 AM
MD540iT's Avatar
set it back to spec
Yes, you might be right. I really want to go EFI, just want it to run decent until I do.
But I am now having a similar problem, where it is running lean while cruising down the hwy, no matter where I set the idle AFR.
What are the possibilities it could be a stuck/leaking Recirc/BOV?? I was thinking it might be bleeding pressure back up into the fuel meter.
Old 08-29-2022, 12:05 PM
WUR ID #’s.........
MD,
Go back and review the numbers on your WUR. Clean and read the numbers again. It should be 0-438-140-xyz. The last 3 digits identify what particular WUR you have. 916 is the casting number, ignore this one. What we need are the last 3 digits (hand stamped) on the WUR.
The pictures below are examples:
Tony
Old 08-29-2022, 03:06 PM
MD540iT's Avatar
one of the 3 i have ends in 091
Old 08-29-2022, 06:46 PM
What are numbers for the other 2 WUR’s you were playing around? Why are you too secretive about sharing these information? How do you expect people to help you if you are withholding critical information? We don’t even know the year and model of the engine. Are you working on a 924?
Tony
Old 08-29-2022, 07:35 PM
