Hello Again All,
I had been busy with work, so the car went on the back burner for a while... I am back on it at the moment and have it running and driving. I just passed its first roadworthy inspection in 17 years!!!! I have done about 4 hours run time since the first run and oil change. it runs OK, however trying to run and hold low RPM whilst driving (below 2krpm) it gets very jerky, or starts to buck. I have to accelerate to stop the bucking. When i accelerate it pulls hard!!!! Cams were reground by someone here in France, they are a little bigger than 964 cams (bit more lift and duration) with lobe separation of 108 degree. it idles lumpy, but never stalls. (see the vid above) I have set the timing at 7degrees as it seemed better and less jerky at 7 degrees, i may try more soon, i just recieved a Classic Retro fit CDI+, so then i can adjust the total too. % of Co2 is 3.5. I know that may be high, but she is still new... Does anyone have any experience with bucking and what the cause of it can be???? Thanks Christian |
Sounds to me that there are still some things to fix. Probably as mentioned vacuum leaks and misadjustment of the CIS. Ignition is worth a look, but from my side I would check up the CIS system. I had similar problems with high idle - it was a totally misadjusted CIS. While playing with the CO screw, idle screw can mimc a proper starting and idling engine when cold, but it shows exactly such problems with too high idle and stalling when being warmed up.
Follow the steps in this video for the basic setup of a CIS engine (the entire video is worth a look): https://www.youtube.com/watch?v=K-OvjlkrgNo&t=2529s I spooled it to the sensor plate height adjustment, this has a huge effect on how the engine starts and run. First and foremost follow these steps for a proper adjustment of a CIS engine: 1. Sensor plate height 2. CO2 screw (the video shows Curts preferred way of dismantling one line on the FD, I prefer the Bosch way on hearing the injectors squeezing) 3. Idle screw (close completely on sitting engine and then 2 turns out) It the FP and CP are good the engine must start rightaway and idling with 5-10° ignition advance. As well cold and warm! A different camshaft affects the idle of course, it will run a bit more rough on idle, but it must start and idle as well as a stock engine beiing cold and warm. Probably you have to play around with CO and run a tin ybit richer than stock, but never as much as 3% CO or more I would say. I own a 930/16 with WebCam 20/21 grind camshafts and it starts rightaway and idles with approx. 1% CO and running stock lambda ECU. Afterwards fine tune the CIS as follows in this video: https://www.youtube.com/watch?v=Ii5k773lwKs Curt has collected some more information here: https://www.klassikats.com/document-center/ Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 12-16-2022 at 05:45 AM.. |
Try it and see what happens.......
Phil, I missed your post. So let me explain to you what would happen if you turned the mixture screw all the way in (clockwise) as previously suggested:
![]() You surely know by now what happens when you lift up the sensor plate while the FP is running. With the mixture screw turned in all the way minus 2 turns back, the plunger is already raised up and will prematurely deliver fuel once the FP starts to run. Try it and keep us posted. Tony |
