Kurt
What's this relay?
I'm pretty new to doing anything related to wiring in my 1983 911SC, figured that a headlight relay would be a pretty easy place to start and came across the relay below. I believe it is the headlight washer relay but wanted to be sure. Anyone know?
Kurt - 1983 911SC |
Headlight Washer Relay
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Kurt
Kurt - 1983 911SC |
["The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender ..yup ..besides the relay answer;-) Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
The one in quotations is indeed not mine...the other is. Thanks!
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 09-08-2022 at 08:20 AM.. |
the first quote has been attributed to Ms, Thatcher
Yes...the quoted portion is Ms. Thatcher. I am a big fan.
She would likely agree with my words as well (below her quote) as well.
