Heater Backdate Question?
Hey guys,
I’ve got the left side heater backdate duct on my motor, but not the right hand side one because I need that space for my A/C compressor. Is the airflow from the left side backdate duct enough to push air through both heater exchanger inlet ports, so I can get enough heat into the cabin? I presume the blower motors inside the cabin will draw enough warm air into the cabin? Advice appreciated. Last edited by 911TT33; 11-14-2024 at 06:34 PM.. |
I have the one duct only, without the blower motors, and it works fine. Sadly though, the car resides in SoCal and not much heat is needed...ever.
Titanium User
You can buy a new right side heat duct from Porsche that clears the AC bracket/compressor. It comes in 3 pieces.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
my backdated unit gets plenty hot using one side - i rarely open the passenger side. being in motion is the key - i wouldn't want to commute in stop and go traffic, if it was truly cold out. ..... and? defrosting could become an issue, RHS. yes?
Agreed on this point. I have backdated mine and have both ducts on with AC, however I often just use the driver side lever and it is plenty! |
Cool. Thanks for confirming guys.
I think I’ll connect up the engine duct to the right hand side heat exchanger so the driver gets all the heat. Oh, this is a RHD vehicle as I’m in Melbourne, Australia 👍🏼 Doesn’t get TOO cold here, and I don’t plan to drive the car much at all in Winter anyway. It’s just a “nice to have” in the event it’s a little chilly when out and about. Curious, is there a part number for the 3 piece right side duct that clears the A/C?! |
check my post here, I modified the existing block off plate for about 20$ and it clears the AC bracket:
https://forums.pelicanparts.com/porsche-911-technical-forum/1169400-1983-sc-heat-backdate.html#post12356155
'83 911SC - Rubinrot Metallic IG: @911.sc.83 |
Titanium User
#5, 6 & 7 plus hardware
![]() http://www.auto atlanta.com/porsche-parts/hardparts.php?dir=911-78-83§ion=105-05
