3.2 vs 964 intake valves question
Same size, but 4X the price for 964 intakes. Gold filled?
206 637 4071
Old 09-17-2022, 12:45 PM
Memories of the factory valves in the early 80s
Bruce
Old 09-17-2022, 12:59 PM
Carmagic.us
rothaus's Avatar
Are these not exact the same ?
49 X 9 X 110.1 mm 45 Deg
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 09-17-2022, 02:38 PM
Look and measure the same, but the price??
Both TRW brand.
Pelican 964 intake 964 105 409 08 $116.50
Pelican 3.2 intake 930 105 409 13 $21.50
Wazzup???
206 637 4071
Old 09-17-2022, 04:25 PM
It's a 914 ...
stownsen914's Avatar
I saw a reference to 3.2 intake valves being sodium filled. I thought that it was usually exhaust valves that were sodium filled. Not sure if it's true that the 3.2 intakes are too, or why it would make them cheaper than other intake valves.
Old 09-17-2022, 04:50 PM
Carmagic.us
rothaus's Avatar
This company in Germany sells them for G-model, 930 and 964
https://partworks.de/partworks-de-porsche-911-g-74-89-2-motorinstandsetzung-6x-einlassventil-fuer-porsche-911-g-turbo-964-ventil.html
Old 09-18-2022, 05:42 AM
I just ran into this predicament comparing SC and Turbo intake valves. (TRW) Dimensionally the same, but the turbo valves are more $$. I just realized I should compare weight.
I think the 964 intakes are hollow, the same valve they used in the 3.2 Clubsport.
it's not leaking....it's just marking it's territory
Old 09-18-2022, 06:21 AM
Interesting. I love a mystery.
206 637 4071
Old 09-18-2022, 07:53 AM
John what is also a mystery is the quality if the sc vs turbo valves. (TRW) I’ve had to return a lot of SC valves due to too much taper in the stem up to .0015” … NEW valves! The turbo valves are consistently perfect.
Old 09-18-2022, 10:38 AM
Yeah, had trouble with those, too. I usually order 12 and sort through them, return the defects, if any.
206 637 4071
Old 09-18-2022, 10:58 AM
All 964s use the same 964 105 409 08 intake valve, including 3.3 and 3.6 turbos. That same intake valve is specified for 78-89 930 turbos by PET.
This is what Porsche 964 training material says about the valves
I have these 964 intakes valves made by TRW (30279 part number) in my 930 engine.
They weight 113 grams each, 10 grams lighter than the original 930 intake valves.
911 SC 1981
Old 09-20-2022, 03:57 AM
Thank you, missed that tidbit over the years.
206 637 4071
Old 09-20-2022, 08:27 AM
