Dept store Quartermaster
lendaddy's Avatar
Now I need a different turbo sump, which one?
Found out last night that my original turbo sump is to long and hits the drivers side exhaust pipe. Is this normal? Do I have to modify my sump or is there a different model I need? Thanks
Cornpoppin' Pony Soldier
Old 05-28-2003, 08:18 AM
lendaddy's Avatar
Anyone? PET shows two different P/N's but does not explain. Thanks
Old 05-28-2003, 10:35 AM
Len, I've got both types at home. Will post pics after 6pm PST if you like.
Old 05-28-2003, 11:13 AM
lendaddy's Avatar
That would be great, Are you selling them?
Old 05-28-2003, 11:27 AM
Will do. I'm not selling yet, because I'm still juggling parts on my engine. Once the situation settles down I might part with one or the other - but I don't know which one yet!
Old 05-28-2003, 12:18 PM
Hey Len, while I have your attention, do you think you could post a picture that shows the mounting area of your wastegate? I'm still not sure about that flange thing I was talking about earlier.
Colin
Old 05-28-2003, 05:46 PM
various suppliers sell a small sump kit with hoses and fittings to do away with the stock setup. it also doesn't vent to the air cleaner. in the $100 range.
206 637 4071
Old 05-28-2003, 05:53 PM
just happened to have one laying around.
206 637 4071
Old 05-28-2003, 06:13 PM
lendaddy's Avatar
Wow thanks guys! I like the idea of the aftermarket piece and doing away with a little more plumbing. Colin I have the rectangular one now. Thanks for the pics. Also, what stage are you at now? Last I read you were thinking of turning her over.
Old 05-29-2003, 05:29 AM
lendaddy's Avatar
JW, can you point me in the direction of a retailer? My search efforts have been fruitless. Or I will gladly pay you a premium for yours if you have no need for it. Thanks again!
Old 05-29-2003, 05:58 AM
that one's for my car. powerhaus sells them. try pelican first of course.
206 637 4071
Old 05-29-2003, 08:12 AM
lendaddy's Avatar
Will do, thanks JW.
Old 05-29-2003, 08:17 AM
It's running! I've done the breakin procedure in the garage and driven around the block a few times. I'm fighting a couple mysterious oil leaks that could be rocker shafts or valve cover issues. Just retorqued the head studs and tightened the rockers.
I'm waiting on a new wastegate spring because the boost was going wayyyy too high (15-16psi) for a new engine. I want to run stock boost for now. So after that I'll be doing some victory laps around the neighborhood. Then I'm going to put in a Carrera cooler and turn to the suspension.
Old 05-29-2003, 08:22 AM
Forced Induction Junkie
WERK I's Avatar
B&B's turbo sump is the same as the one illustrated in John Walker's response. BTW, it was the only piece in the 930 header kit that did NOT have a fitment issue.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-29-2003, 06:09 PM
B+B fitment issue? really?
206 637 4071
Old 05-29-2003, 06:52 PM
