Any chance you have the parts list for that "Triangle of death". I've done much searching and heard it referenced a bunch but have not found a "And these are the things to fix to resolve the issue" so I've just been ordering everying on the back side of the motor. Would love a parts list if you've got one.\ Love the callout on cheap parts (decklid strut etc)! thanks much. |
930 606 915 00 CHT Sensor 0 261 210 002 Crank Reference Sensors x2 The crankcase breather tower gasket, thermostat O-ring, and oil pressure warning lamp switch are known as the “Triangle of Death” 930 107 791 02 Breather Plate Gasket 900 123 007 30 Seal ring 911 606 230 00 Oil Pressure Sender Here's the other parts from my recent, intake-off, fuel line service: 930 110 197 14 Intake Manifold Gaskets 930 110 459 00 Intake Manifold Flanges 911 375 043 07 Clubsport Engine Mounts 9P1 129 487 Vacuum Line Connectors x2 928 573 727 02 Vacuum Hose Connector Griffith Fuel Line set We tested the fuel diaphragms, cleaned the throttle body and sent the injectors out for refurbishing. |
thanks much. parts ordered. |
| All times are GMT -8. The time now is 05:39 PM. |
