Idle Surdging
My friend has a 83 3.0 Targa with a fresh rebuild by Tony Miller. Tony bought out Gary Wiggellsworth, Translog in York Pa. He has 1000 miles on it and when it warms up, the idle surdges from 600rpm's to 1200rpm's. When he drives it, it runs fine when he's on the throttle. Any thoughts?
Probably way too rich on the idle mixture adjustment.
as John said..also do not forget the engine need 1000 miles check up after the rebuild....looks like it is due...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
It's FI. What do you adjust? He's not a mechanic and I have 2 911's that have Webers. I don't know anything about FI cars. Thanks!!
Maybe so a search for CIS mixture adjustment, right here on this forum. 3mm LONG allen wrench down a little hole between the fuel distributor and intake boot. Hard to see, sometimes you have to drag the allen wrench in the gap to find the hole. Engage the adjuster and turn a very small amount counter-clockwise when it's running until it smooths out. Ballpark backyard fix.
Clarification........
Stock, I'm guessing CIS.
