3.0 teardown
This 3.0 was running badly........reportedly was making nasty banging noises....it was shipped to me to tear-down/investigate
I think i spotted the problem.....
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Hah! Oops!
Sent from my Pixel 7 using Tapatalk |
I have hear of people doing that but never actually seen a case till now.
Wrong Orientation………
Did they have this on both sides?
Tony |
yep...this is the first time I've seen this too.....just on the 4,5,6 side...plugs on the 1,2,3 side looked sooty/rich...plugs on the 4,5,6 side looked unused.....leakdown on the 1,2,3 side good, on the 4,5,6 side bad...likely bent valves. not easy to see in the pic, but definitely valve/pistons trying to share the same space, at the same time.
Also, no base gaskets installed....which added to the interference.
Drugs.
Looks like someone got lucky could have been way worse.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
kinda slow
Genuinely curious how long it ran like this, impressive.
1983 911 SC Coupe |
zero
Zero miles......
Do I see Pistons Upside Down?
Wow,as they say "don't drink and drive " or top overhaul a 911 motor,looks like the pistons have been attacked with a grinding disk !!! ???.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Yes, that is what you are looking at there....pistons are rotated 180 degrees out. Lot's of other strange assembly practices going on as well....all rockers shafts are RTV'd on the ends , no base gaskets on the cylinders..... kind of a mess....but i'll make it all better.
