964 Sport/race exhaust manifold?
Hey guys, anyone with knowledge/experience on aftermarket 964 exhaust manifold for 911 muffler?
If no one makes them in europe, who in the states?
Is there anyone who makes them to order. I have spent SOME time searching now...
I'm not looking for a larger diameter, but without heater boxes. And if you could get them with "V clamps" maybe....
What the heck, what if you could get them as step headers..
Or in the "right" length primaries...
Does anyone know "in the neighborhood prices" for this kind of stuff?
Old 11-28-2022, 01:36 AM
Crotchety Old Bastard
RarlyL8's Avatar
There are a few companies producing headers for the 964 engine. Systems for the 964 chassis however would be a bit more involved than those for G-body and Early 911 transplants.
A "standard" 911 muffler will not fit in a 964 chassis, nor would it have the proper capacity for the 964 engine. We produce custom systems for this application and for 964 transplants into earlier chassis. Headers are sized per engine spec with configuration depending upon which chassis the engine is installed (the 964 engine console is much larger than that of a 911). Custom mufflers are designed per spec as well to flow the proper amount and with tailpipes exiting where desired.
This system was built for a 964-based engine G-body transplant.
Old 11-28-2022, 08:23 AM
group911@aol.co's Avatar
S-Car-Go like these
Thanks,
Bob
group911@aol.com
Old 11-28-2022, 07:38 PM
Arlo911's Avatar
Here in Europe there's DW Technik, M&M Exhaust, Cargraphic, Friedrich and others.
I only have experience with DW Technik, and can highly recommend Dieter's work.
If it's just regular headers you might find a pair at Rosepassion?
Old 11-29-2022, 12:28 AM
@aircooled4evr -- does your 964 need to remain emission compliant? if you ditch heater boxes, how will you handle defrosting the windshield?
Old 11-29-2022, 07:57 AM
hi Arlo911
I like the price of RosePassion's 964 exhaust manifold!
But NOT the design, or quality of the collector. And if I intend to build the system with V clamps, and for LM2 lambda ...
Old 12-07-2022, 06:16 AM
Bill Verburg's Avatar
I just put a Fabspeed RSR on my 993 engine is my '76 Carrera
It's a very nice piece of work
Bill Verburg
Old 12-07-2022, 06:20 AM
hi RarlyL8
What a beautiful example!
I forgot to give all the information needed to properly answer my question...
My car is a 1978 SC and I am rebuilding a 3.0 engine with 964 cylinder heads.
(It ends up as a 3.3)
Right now I have an old muffler lying around, but I don't know if it will be this one (rebuilt in terms of sound) or e.g. a Danish 2 in 2 out.... (I am not going to use the old heating system!)
I imagined I could make my own spacers from manifold to muffler. and use V clamps, so that you could switch between test mufflers in the future more quickly.
Old 12-07-2022, 06:31 AM
Oh yes!
However, I would like to make it a little more old school.. (and I won't be using the old heating system)
Old 12-07-2022, 06:36 AM
hi darrin
I intend to use a modern petrol heater in the smuggler's box.
(and my 78' SC is so old that it doesn't need to be emissions compliant)
Old 12-07-2022, 06:41 AM
Originally Posted by group911@aol.co View Post
S-Car-Go like these
This is EXACTLY what I was thinking!
My engine layout will clearly benefit from longer primaries/manifold system.... and that could actually be possible with this system
Old 12-07-2022, 06:50 AM
RarlyL8's Avatar
The system I pictured previously has V-band connection at the collector outlet with custom sized secondary that connects to the custom muffler via larger diameter OE style 2-bolt flanges. That gives you the ability to easily swap out the muffler plus ads adjustability.
Length and diameters are custom per engine and chassis spec. This particular set has 1.75" primaries and a 2.5" collector reducing to 2.25" secondaries. This mates to 2.25" muffler inlets.
These have 2.5" v-band secondaries mating to a high flow muffler with 2.5" inlets. The engine these were designed for requires more flow at higher RPM.
Old 12-07-2022, 07:18 AM
Northern Motorhead
wildcat077's Avatar
Bill,
Did you do anything about the droning yet with the Fabspeed system ?
I have the same setup on my 89 with a 95 3.6 and it's quite annoying on long trips.I shove a Car Chemistry twin disc insert in each tailpipe when i plan on driving far , but in the city the sound is somewhat more bearable.
The fit and finish with the Fabspeed stuff was pretty good but i'd sure like to have some of Rarly's artwork on my car one day !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-07-2022, 12:34 PM
Originally Posted by wildcat077 View Post
Bill,
Haven't had a chance to drive it much, as I'm still adjusting things after a major rebuild of the engine and trans
haven't noticed any drone though
The fit and finish are exceptional, though i'd prefer black
I don't like how wide the headers run, had to work it a bit to keep the oil line separated
i do like the access to the engine mounted oil filter
Bill Verburg
Old 12-07-2022, 12:56 PM
jmz jmz is online now
jmz's Avatar
Originally Posted by Aircooled4evr View Post
hi RarlyL8
That’s only a “muffler” in namesake.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 12-07-2022, 01:04 PM
Contact William Knight. He has a variety of options.
Old 12-08-2022, 09:58 AM
The prices for these systems are ridiculous in europe... Far better in the states!
Unfortunately, freight + duty & VAT must be added to all of this. let me give an example.
1 piece. exhaust manifold = $1500
For you to see the situation (which is good right now): $1 = 7.06 Danish kroner.
So: $1500 X 7.06 = DKK 10,590.
A good rule of thumb is: Multiply $ by 10 and you have the price including shipping, duty & VAT. Now it's DKK 15000
Result: I pay (at least!) $2125….
(the price of 1500 is plucked out of thin air, and is probably higher in reality)
Holy C... Our hobby has become expensive!
I gee wish I lived in the states..
Old 12-12-2022, 01:33 PM
