-   -   Custom Triple and Quad Gauges (http://forums.pelicanparts.com/porsche-911-technical-forum/1128311-custom-triple-quad-gauges.html)
jbell959 10-17-2022 09:01 PM
Well, it's almost time to build another batch of triple and quad gauges. I started building the last batch in May/Jun and I built about 15 gauges. I'm probably not going to take that many orders for this next round so if you're interested in one, let me know early. I will start this building this batch in January but I need to get all the orders in before Thanksgiving. The next batch will probably be around May/Jun.
If you're interested in a quad or triple gauge please fill out the form and I'll get back to you with an estimate and any questions.
https://docs.google.com/forms/d/e/1FAIpQLSeKfN5oK1IoIvy0WaOXr-1M5Lc2QwozaCwlsiEG32Vy50CN7A/viewform?usp=sf_link
jbell959 10-17-2022 09:03 PM
Here are a few of the gauges from the last batch
http://forums.pelicanparts.com/uploa...1666067226.jpg
porschedude996 10-18-2022 08:47 PM
You never cease to amaze me with your talents.
I was looking at the picture with the AFR Gage and wonder if the controller is inside the gage and a Lamda plugs into gage?
I’m enjoying my gage set you did for me.
Jeff Alton 10-18-2022 09:52 PM
Very Nice,
For some reason we did not realize you produced these. Will make them available to all our clients.
Cheers
75 911s 10-19-2022 08:04 AM
John,
I'm in for a quad gauge for my 914 6 conversion. I'll reach out.
1979-930 10-19-2022 08:14 AM
Is that fuel pressure in the first one with the AFR?
Do we need to supply a donor gauge?
Adding fuel pressure and AFR would allow me to ditch the digital gauge and put the clock back.
porschedude996 10-19-2022 08:39 AM
I think that is Oil or Oel Pressure in Atmospheres or Bar. Each whole increment is 14.7psig. They do look great, don’t they?
jbell959 10-19-2022 03:25 PM
Hey Keith, No, the wideband controller is not built into the gauge. These gauges accept a 0-5V analog signal from the wideband controller. Most of the controllers (Innovate, AEM, PLX, 14Point7, etc) provide this type of signal.
Originally Posted by Jeff Alton (Post 11825124)
Very Nice,
Cheers
Thanks Jeff... I build these in batches just a few times a year, but let me know because I often have enough parts lying around that I can put one together.
Originally Posted by 75 911s (Post 11825366)
John,
Hey Duane... Do me a favor and fill out the google form if you're interested in one. It gets crazy trying to keep track of things and the forms make it a little easier. Cheers
Yeah, that's oil pressure on that gauge but I can't see any reason we couldn't build one for fuel pressure. I control the AFR gauges using a little microcontroller in the gauge so if we can't find a VDO fuel pressure gauge that will work I can take the signal from just about any sender and adapt it to the gauge movement (If that makes any sense)
jbell959 10-19-2022 03:32 PM
As soon as I hit submit on that last message I remembered that I built this small combo gauge with fuel pressure for another Pelican's early race car. I forgot what fuel pressure sender we used (I can go back to my notes) but I already have the circuit to control it.
http://forums.pelicanparts.com/uploa...1666218659.jpg
jakg104 10-20-2022 11:12 AM
John recently redid my gauges and they are absolutely flawless. Cannot say enough great things about your work, John!!
Thanks for being an awesome community supporter with your amazing talents!
Gretz 10-25-2022 10:54 AM
Another happy customer here. Mine look great. Thanks, John!
FA-18C 10-25-2022 03:03 PM
John, I sent a form, and am hoping to add volt meter and arm to fuel and oil level gauge. Would I send you the gauge?
jbell959 10-25-2022 03:09 PM
I need to go through the form submissions and get back to everyone. I'm hoping to do that tomorrow. Unfortunately, it's not possible to squeeze 4 gauges into the small fuel/oil level gauges. I can add one to make a small triple gauge but that's it. Even fitting 3 was a challenge.
All the triple and quad gauges in the picture are made to replace the oil temp/pressure gauge.
FA-18C 10-25-2022 03:37 PM
That makes sense, is it reasonable to add AFR to fuel and oil level small gauge? That is my end game, would maybe add voltage to clock later 😁
I am envious of your ability to do this!
jbell959 11-01-2022 08:26 PM
Sorry I haven't replied to everyone that submitted a form. I will do that this week.
jbell959 11-12-2022 06:15 AM
Still a few spots open for this next batch.
bv911 11-12-2022 12:48 PM
Your talents might be overkill for what I’m looking for, but nothing ventured, nothing gained, so here goes: would you make a clock replacement gauge with a volt meter and ammeter in it?
(Since not a triple or quad, figured I’d ask before filling out your form.)
And yeah, nice work…!
shahram 11-15-2022 03:40 AM
Subscribed
jbell959 11-23-2022 06:47 AM
Last bump before I finalize the list for this next batch.
FA-18C 11-23-2022 07:44 AM
John, let me know when you are ready to go to work, I only need to pull my clock out, have a plug inboound to cover it. I can get this boxed up next week and headed your way.
What is the typical turn around?
ALSO - do you have a recommended WBO2 set up that will work with the analog gauge? Sal has offered some insight as well, but that is on my post-Christmas shopping list.
Happy Thanksgiving!
