Front Struts on 84-89 Carrera...When to Replace.
How long can the front struts last on a 84-89 Carrera , assuming they have never been replaced? .. Are we talking 100K miles, 120K, 150K etc?? Assume the car has never been raced and taken good care of its entire life.
Thanks,
Bilstein recommends every 75K. I am sure it depends largely on the type of driving of each individual. But 75K is probably a good basic figure.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Purchased my '87 with 67K miles. Front shocks felt OK. Did bumper test. No bounce. Rode nice. Freshened front suspension at 77K. Front struts could easily be compressed and extended by hand. Car is much better now with new Bilstein HD.
how much are the struts and is this a DYI home repair or better take it to a professional?
Real simple, check our host, they carry everything that you wil need,
for the inserts -- not really the struts per se (that would be more involved) but the struts don't wear out -- except after centuries
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
which one is it? |
What he was trying to say was the actual stut does not wear out, but the insert does. They are easily replaced.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
Bingo
The struts do wear out, symptoms are pulsing through the steering wheel and brake pedal. I'm on my second set of struts & third set of inserts on my oemed Bilstein C3, same for a friend w/ a '78 930.
Ok. But... Those are raced cars - right? The initial poster said "Assume the car has never been raced..." so his struts should last a long, long time, whereas the inserts are likely good for 75k miles or so.
Since we're on the topic... Is there a test one can give the strut body -- once the pulsing is felt. Or do you just have to try and rule out everything else, then end up with nothing left but the strut itself.
I think if the o.d. of the strut is less than the i.d. of the inner race of the large inner bearing, then you're looking at strut replacement. The inner wheel bearing should sort of press onto the strut with a little resistance.
If the front end doesn't do the wheel hop too bad, especially under braking, then the insert is ok. Torsion bars don't wallow up and down by nature, so the typical bounce test doesn't really work on older Porsches. |
-= Kaliv Farstryder =- '87 Porsche 911 |
Senior Member
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
ah, maybe I should clarify that I was talking about wear of the spindle, not really the insert.
Glad I found this post...my '88 has 200k on the clock with, AFAIK, the original inserts so obviously shot. BUT, the comment about pulsing caught my attention. My car is RARELY driven and I've noticed when I do finally drive it I get a distinct pulsing in the steering wheel on slow right turns that goes away fairly quickly. Is this a bad strut symptom? I recall replacing the outer front bearings at some point in the past but not the inner if I recall correctly. Also, are there more than one struts on the Carreras? I seem to recall someone saying there are inner and outer thread versions. I think my car has the "outer" version.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I would guess that what you describe is not that Are you sure that what you have are Bilstein? green w/ a roll pin near the bottom
The 9 Store
Everything wears out. Some parts quicker than others. Bearing and bushing surfaces inside the strut housing and on the wheel bearing spindle definitely wear.
All used parts sold as is. |
Behind the Sun
New bushings all around and new struts with proper alignment and tires feels soooo good in my bum
To my it's about the driving experience and my enjoyment |
88911couoe - “ My car is RARELY driven and I've noticed when I do finally drive it I get a distinct pulsing in the steering wheel on slow right turns that goes away fairly quickly.
- steering wheel impulse can be as simple as low tire pressure, out of balance, alignment issue, worn ball joints, and a steering wheel shimmy driving at speeds. Not driving can seize up a caliper, corrosion on rotor. Brake pedal pulse with steering wheel impulse could be a combination of the above and felt at braking including warped rotor(s). Bearing can be checked by jacking up and wiggle the tire holding at 3 & 9 o’clock And 12 & 6 o’clock. Very noisy if they’re really bad. Check the tire wear for indicators. |
