1985 Carrera
911 3.2 Weird Engine Sound at Cold Start (Video)
Hi Team,
My 3.2 has developed a weird sound at start up - Video Link Here -
https://www.youtube.com/shorts/GkJfe7jEEpo
To me it sounds like the noise is a pulley bearing.
I thought perhaps it was the AC or Alternator bearing going, but when putting my ear to them with a screwdriver, it sounds smooth.
Also to note, after 10min of driving the sound goes away. As its not a metallic sound, I am scratching my head as to what it is.
Any help on this? Has anyone had this before? Sound is definitely coming from the centre of the engine and is loudest near the fan.
Thanks.
Old 10-18-2022, 07:27 PM
I would pull all the belts and run it up and see if the noise persists and work back from there. Probably the only way to determine the fault if any.
Old 10-18-2022, 09:41 PM
1985 Carrera
@OSC911 Thanks, I have gone and done that, and luckily the sound has gone Now my next task is to isolate between the alternator and the AC. The alternator though when spinning the shaft definitely makes a much worse sound. How much are new alternators going for these days haha
Old 10-19-2022, 02:21 AM
If it is the alternator there is a guy in Brisbane that makes new alternators using all new Bosch parts and machined housing assembly. They are called K3 i think if I remember correctly. I have one in my 3.0 litre and they are a work of art - beautifully made. Let me know if you need for me to chase up the contact number.
Hopefully it is just belt noise which I have heard similar to yours. I would try a set of belts first.
Old 10-19-2022, 03:16 AM
Jeff Alton's Avatar
You should be able to find a local place to rebuild the alternator as well...
Cheers
www.turn3autosport.com
Old 10-21-2022, 08:52 PM
That's fond- just deglaze
Hi LBEEMING- I listened to your video link- it does sound similar to what I experienced in 2019.
As a further example, I've got Forum member 911 Euro's video of his noise posted in my link...
1986 Alternator replacement- Rumbling noise now gone, hidden bolt on A/C plate
My issue did turn out to be the alternator bearings- hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 10-22-2022, 09:59 AM
1985 Carrera
Thanks, appreciate it
I loosened the alternator belt a bit and the noise went. So I am guessing new bearings are required soon!
Old 10-27-2022, 08:45 PM
