Targa_PB_78_SC
Cheers
BareRearedRookie |
I guess it just depends on whatever somebody threw on in the past.
1982 911SC |
Intake fasteners.......
Mike, The intake runner fasteners could be either 12, 13, or even 14 mm nuts. That’s the reason I have different flex sockets for this job. The OEM self-locking nuts are 12 mm, the 13 and 14 mm nuts are replacement fasteners. The 13-mm is the most common fasteners I find on these motors unless you still have the original fasteners (12-mm self-locking). Just use the appropriate tool. Tony |
So should I start with the runners ?
took my 90 minutes including jacking and i did it with a small partial drop , didnt even disconnect coupler, just did a few inches..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
obviously start with all heater lines and blower motor and ducting , pull plug wires and then you will have a much clearer view of everything, fuel lines and sensor/ electrical lines linkages , then start undoing runners and see what holds you up.
Targa_PB_78_SC
If you do a partial drop, be sure to undo the coupler! Sometimes a partial drop can get away from you and if it goes farther than you want, you’ll be really glad you spent the extra “30 seconds” it takes to disconnect the shift coupler. Disconnect the appropriate wires too, check out partial drop threads for advice. May as well disconnect the line to the booster at the airbox too if your dropping, it has to come off anyway. It’s on the 1,2,3 side.
It’s only 4 screws and then a 4 mm Allen wrench. You’ll want a lengthy one to reach the coupler. Or, don’t disconnect the coupler and risk bending something expensive if your partial drop gets away from you. If you can get the nuts off number 6 runner, without a partial drop you might not need one. Then you might beat Iceman’s 90 minute time ![]() You’ll need to pull your fuel injectors. They can be persnickety too, if they don’t just pull out easily, then a crows foot wrench (or an open end wrench) around the injector so you can use it to brace your leverage (screw driver) helps move the injector up. Having done this removal and install both ways, there is no way I’ll ever do it again in SITU. However, dropping the engine and transmission does look formidable and once dropped you need to have a place to work on the engine. Not sure what plugs iceman was talking about. Maybe the electrical plugs (there are four of these) to the WUR, CSV, AAV and the one to the plate near/behind the FD on the 4,5,6 side. These just pull off, and don’t loose those pesky clips, had one sneak into a cylinder, glad they are magnetic. Don’t overlook the nut holding the air-box to the engine plate at the front (towards the steering wheel) or the spring on number 2 runner. Be sure to stuff clean rags into the open cylinders as soon as you can. And buy the way not all CIS removals are equal. You might have an “easy” year. Some years are too hard even for pros to remove in SITU. Maybe all SC’s are equal? Not sure, I recall reading mine was easy ‘78. Oh, be sure to set your timer before you start
BareRearedRookie |
Does having a 4 post lift make things easier? I mean not having to work bent over as much. If I manage to undo all the runners can it be pulled out through the trunk lid?
Targa_PB_78_SC
That was smart. I pulled my injectors because I wanted to change the o-rings and broken sleeves and for me, it’s a bit easier to pull the injectors with the runners firmly bolted.
BareRearedRookie |
Targa_PB_78_SC
Then you do a happy dance for good luck and lift the CIS beast up and out! Multiple dances required for the install
BareRearedRookie |
How available are the hoses if I need to replace them?
Pelican sells all the sizes, just measure inside and outside diameters and look them up- they will be in mm.
Smart money is to replace them all- not much money in the long run.
Rutager West 1977 911S Targa Chocolate Brown |
Everything is available and not too expensive, but the vacuum manifold that connects to the intake boot and the auxiliary air valves is $$$ and hard to find. I've seen people suggest having them made if they need replacement.
1982 911SC |
you can talk about this all day and try to plan for every single eventuality , best thing is to just roll up your sleeves and get at it .
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) Last edited by theiceman; 11-03-2022 at 07:54 AM.. |
Your right it's just mustering up the courage to begin.
The car is running right now but the long winter is coming here to Montreal and would be a good project to work on during those long days. |
Senior Member
I too wonder why. If there is troubleshooting needed, then I think that is best done in situ.
But in any case, if I needed to remove a CIS, I would do a partial engine drop and remove it as one piece. Then I would reinstall it as one piece. Ot is fairly remarkable how few things need to be disconnected for a partial engine drop. A couple of electrical plugs. A fuel connection. Shift coupler. And, I think, oil lines. throttle linkage. Heck....the entire engine and tranny can come out rather quickly if you use a drill or air wrench to remove the CV bolts. I think Mr. Walker does it in about a half hour, probably. But then, he's a pro with all the right equipment and something close to 50 years experience. Oh...and once you are in there, be sure to replace the o-ring in the Devil's Triangle that tends to fail and leak. Part of the engine oil system, near the engine-mounted oil cooler.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I don't see how doing a partial engine drop will give me more access to the back components.
Targa_PB_78_SC
You will have more wrench position variability with a partial drop for number 6. Try to get the inside nut off of runner 6 without a partial. Once it's off, getting it back on is a challenge too, especially with the oil cooler shroud in place (IIRC). Keep us posted. And good luck.
BareRearedRookie |
lose early ... get it out of the way and you will be much happier.
