Kind of Blue
Help with Weber 40 identification
In a few weeks, I'm sending the '71 off to be converted to EFI (Clewett ITBs, ECU Masters engine management, coil-on-plug, new lines, pump, and going from 17 to 22 gallon tank).
The decision is due to s lack of reliable availability of ethanol-free fuel which has done a number on my Webers. I'm planning to have them rebuilt to sell, but can someone help me identify what kind I have? I've googled everything on the side and can't find anything to help me determine where and when they were made. ![]()
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
this is a picture of an idtp carburettor they were used on 69 911 t's and 914 sixers
it's not leaking....it's just marking it's territory |
Heads up, they are the least valuable of the Italian type 40IDA.
Kind of Blue
High quality metal, body and paint work http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/ |
Unless you rebuild them yourself you might consider selling them as is. You can easily spend 3-4 thousand on a full mechanical and cosmetic rebuild. As is they’re probably worth $1800-$2200
I can’t see anyone paying $5-6,000 for them post rebuild. However, I’ve been blown away by BAT buyers many times.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Those are IDTP Webers as installed on 911T for 1969 year model. (914/6 used IDTP1 Webers, note the difference in model number which indicates they installation in a mid-engine location.) They are OK for use on engines with up to 32mm venturis with a minor modification allowing tuning of the air correction jet for the idle/progression circuit.
As recommended above, let new buyer pay for rebuild or refurbishment.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Uncertifiable!!!
![]() ![]() I apologize for the ugly gold paint applied by a previous owner…LOL Which is the proper model for the ‘71T? TIA Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
The 71T would have come with Zenith 40TIN’s. The gold paint actually doesn’t look too far off from the color they are supposed to be! haha.
