Kind of Blue
MrBonus's Avatar
Help with Weber 40 identification
In a few weeks, I'm sending the '71 off to be converted to EFI (Clewett ITBs, ECU Masters engine management, coil-on-plug, new lines, pump, and going from 17 to 22 gallon tank).
The decision is due to s lack of reliable availability of ethanol-free fuel which has done a number on my Webers. I'm planning to have them rebuilt to sell, but can someone help me identify what kind I have?
I've googled everything on the side and can't find anything to help me determine where and when they were made.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 11-04-2022, 09:10 AM
this is a picture of an idtp carburettor they were used on 69 911 t's and 914 sixers
it's not leaking....it's just marking it's territory
Old 11-04-2022, 01:52 PM
Heads up, they are the least valuable of the Italian type 40IDA.
Old 11-04-2022, 01:58 PM
Kind of Blue
MrBonus's Avatar
Thanks, guys. Once they're rebuilt, I'll toss them up on BaT and whatever I get, I get.
Old 11-04-2022, 02:23 PM
Somebody will overpay for them there you can be sure.
High quality metal, body and paint work
http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/
Old 11-04-2022, 03:02 PM
Unless you rebuild them yourself you might consider selling them as is. You can easily spend 3-4 thousand on a full mechanical and cosmetic rebuild. As is they’re probably worth $1800-$2200
I can’t see anyone paying $5-6,000 for them post rebuild. However, I’ve been blown away by BAT buyers many times.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 11-04-2022, 06:12 PM
1QuickS's Avatar
Those are IDTP Webers as installed on 911T for 1969 year model. (914/6 used IDTP1 Webers, note the difference in model number which indicates they installation in a mid-engine location.) They are OK for use on engines with up to 32mm venturis with a minor modification allowing tuning of the air correction jet for the idle/progression circuit.
As recommended above, let new buyer pay for rebuild or refurbishment.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-04-2022, 10:29 PM
Uncertifiable!!!
Uwon's Avatar
Interesting. I picked up a molested ‘71T with matching numbers which also had the same model number Webers which you say are from a ‘69.
I apologize for the ugly gold paint applied by a previous owner…LOL
Which is the proper model for the ‘71T?
TIA
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-05-2022, 04:37 AM
TIA
Johan
The 71T would have come with Zenith 40TIN’s. The gold paint actually doesn’t look too far off from the color they are supposed to be! haha.
Old 11-05-2022, 05:28 AM
Old 11-05-2022, 05:47 AM
