Where to tap into turn signal wiring
I picked up a DRL-1 from Daniel Stern lighting..
https://dastern.torque.net/Mods/DRL/DRL1.html
From the instructions, it needs to tap into parking lights/blinkers...
https://www.danielsternlighting.com/tech/markerflash/markerflash.html
Besides in the headlight bucket/behind the bumper - where can I get access to these wires to tap into them?
Has anybody installed this and have any good pictures?
Old 01-03-2025, 02:15 PM
Uncertifiable!!!
Uwon's Avatar
Oh man, those instructions are gruesome. Not necessary in 911 relatively uncomplicated electrical systems.
It would be helpful if you would post the year of your P-car.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-04-2025, 06:46 AM
Profile says 86 Carrera 3.2.
Gilles
RoW 88 Carrera coupé
Old 01-04-2025, 08:03 AM
ROW '78 911 Targa
timmy2's Avatar
Easiest location to interrupt the output as it appears you need to do for this device, would be at the fuse panel.
Signals are fuses 9 & 10, running lamps are fuses 3 & 4.
Counting back from the headlight end of the fuse panel. Ignore the markings on the fuse panels.
Bottom of fuses are output to the lamps for front lighting.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-04-2025, 08:22 AM
Uncertifiable!!!
Uwon's Avatar
Interesting. I don’t see that on my iPhone.
Johan
Old 01-04-2025, 08:54 AM
Johan
Currently using my PC. When using smartphone version of board, I don't see people's profile either. Maybe lack of space.
Gilles
Old 01-04-2025, 08:59 AM
Yeah, sorry about that... 86 Carrera Coupe..
Was hoping to find a nice long run of wiring somewhere easy to get to.. doesn't sound like that is going to happen fuse block might be best.....
Old 01-04-2025, 09:27 AM
spoke's Avatar
About using the front turnsignal as a DRL, you may want to change the turnsignals to LEDs. The OEM bulb will burn 21W with the bright filament. Since it could be constantly on for hours, it may overheat the plastic housing. Both brake housings on my '71 914 are melted above the brakes lights from sitting on the brakes for a long period of time.
Find Spoke's LED Products:
www.spokeworksled.com
Old 01-13-2025, 05:01 PM
