-   -   Re-sizing BBS E50 to 17" (http://forums.pelicanparts.com/porsche-911-technical-forum/1130330-re-sizing-bbs-e50-17-a.html)
DSM 02-06-2024 09:01 AM
Something I noticed. Rear 5.5 outer 17" was a bit wider than 16". The 16" didn't rub at all but the 17" did slightly. Had to set a bunch of negative camber to fix that. Think the the 17" tire has more to do with the rubbing as opposed to the slightly wider rim.
https://lh3.googleusercontent.com/dr...mLxH-hHQ=s1600
https://lh3.googleusercontent.com/dr...1HUaZSew=s1600
https://lh3.googleusercontent.com/dr...GMw452cA=s1600
Nik0o0 02-06-2024 12:20 PM
Hi DSM. Curious question. Are you running the factory 930
Spacers on the car with this setup?
DSM 02-07-2024 09:14 AM
Please note:
Went with different sealant because it was easier to get.
Blue 77 930 is a US Spec (Came with 21mm front & 28mm rear spacers)
The New 17" BBS E50 run the 21mm front & no spacer in rear.
https://lh3.googleusercontent.com/dr...9bbxkN3C=s1600
https://lh3.googleusercontent.com/dr...zbYD3xSA=s1600
https://lh3.googleusercontent.com/dr...TOQldjmG=s1600
https://lh3.googleusercontent.com/dr...U6gHKsRQ=s1600
https://lh3.googleusercontent.com/dr...51iBJv_c=s1600
https://lh3.googleusercontent.com/dr...oE5ckvVw=s1600
https://lh3.googleusercontent.com/dr...GIPwY4pw=s1600
skinnerd 02-07-2024 10:40 PM
Really looks great!
Badbiturbo 08-07-2025 10:24 AM
Old post bump but does anyone know the size mounting hardware to run with these using the inserts? Thanks
YellowBee69 08-07-2025 10:57 AM
Are you asking what size bolts are used to assemble the wheels? Surprisingly, call BBS and ask for E50 hardware. I just rebuilt mine and I was shockingly surprised how inexpensive it was to buy their hardware. http://forums.pelicanparts.com/uploa...1754589359.jpg
Badbiturbo 08-08-2025 05:38 AM
Yes I was referring to the hardware used to assemble the face to the barrel/lips. I'll have to give the a call. Also are the inserts pressed into the faces or is it just a simple slip fit?
YellowBee69 08-08-2025 08:19 AM
The faces are not pressed in. They simply sit in the barrel. Its not a snug fit but there isnt much wiggle room, so you have to be careful not to scratch the barrels if you have alot of offset! My wheels I had to slide them in a good 4-5" I was worried id get scratch lines but didnt!
DSM 08-09-2025 11:59 AM
http://forums.pelicanparts.com/uploa...1754765334.jpg
http://forums.pelicanparts.com/uploa...1754765430.jpg
http://forums.pelicanparts.com/uploa...1754766160.jpg
DSM 08-09-2025 12:16 PM
http://forums.pelicanparts.com/uploa...1754766410.jpg
DSM 08-09-2025 12:29 PM
http://forums.pelicanparts.com/uploa...1754767721.jpg
