Performance Brakes for 911 1973 recomendation
Hello, looking for performance brakes ( caliper /disks) for a 911S 1973 . Any recomendations.. for track use
Old 11-20-2022, 03:13 PM
Bill Verburg's Avatar
stock w/ track pads and performance fluid, Castrol SRF is the best), should be fine for most
+ .25 is change fronts to 24mm Carrera rotors and calipers
+2 change to 930
The primary concern is thermal capacity
Here's a comparison of the thermal indexs of various caliper/rotor combos
Bill Verburg
Old 11-20-2022, 03:21 PM
Great! Im overseas in Latín América.. Any brands or sites I can purchase online you can recomend?
Old 11-20-2022, 03:30 PM
I would rather be driving
jpnovak's Avatar
good fluid. good pads and cooling ducts to put air into the rotor eye.
Old 11-20-2022, 03:36 PM
I found Bill's "+.25" change to Carrera calipers and discs to be all I needed on my somewhat aggressively tracked '72. I ran the aluminum "S" calipers for years, but found when running slicks I had enough grip to somewhat overheat them on warmer days. The pedal would go soft, and it felt almost as if I could feel those aluminum calipers spreading. Not the case, of course, but certainly the feel. The Carrera "wide A" calipers and discs solved the problem and have proven to be all I need. This is in a 2,200 pound car with about 250 horsepower motivating it and, like I said, driven aggressively on the track.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 11-20-2022, 07:23 PM
I will also agree with Bill's wisdom. On a light car, the Carrera brake components are all that you need. Upgrade to SRF brake fluid, good pads, and add the 993 air deflectors to get some air to the rotors. Use the money you saved for track time.
1973 911 RS replica, Irish Green
1972 BMW 2002
1968 BMW 1600
1965 Triumph TR4A
1961 Land Rover Series 2 88
Old 11-21-2022, 04:19 PM
I’ve been really happy with my stop tech setup
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 11-21-2022, 07:09 PM
Nice car!
Old 11-22-2022, 07:16 AM
IROC's Avatar
+2...or 3... Carrera brakes on my 2400 lbs, 245 hp car work just fine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-22-2022, 07:50 AM
