Advice on Filling in gaps around front mounted Oil cooler : Race car
Hi Peeps. My 74 911 RSR vintage race car has a front mounted oil cooler. its mounted , of course, to the chassis and the exhaust is directed downward in the rear. its about 5-6 inches from the front screen and I have aluminum flashing on top and bottom to channel the air at the cooler. however, there are big gaps on the sides because the bumper is so irregular, you cannot shape any metal to fit it properly. I am told you lose alot of air flow thru the cooler if there are easier paths for it to follow: so it does not setup a good boundary layer. my car tends to run hot anyway so concerned about this ( and of course global warming is upon us...).
One idea I had was to squirt that expandable foam from a rattle can in the gaps. it then hardens and it pretty airtight. likely makes a mess when you have to remove the bumper but that's another issue.
any thoughts on this approach or others? or am I just overthinking this.,..
thank you as always..frank
Old 07-29-2022, 06:53 PM
I’d jump on McMaster carr and order some soft foam tubes. I got a few for my rally car and was able to stuff them into the crack between bulkhead and engine. Might be a better solution then great stuff.
Old 07-29-2022, 08:16 PM
It's a 914 ...
stownsen914's Avatar
Hey Frank - for gaps up to 3/4", use that foam insulation tape like you get at Home Depot. It fills gaps and conforms to irregular shapes very nicely. If the gaps are larger, riveted pieces of aluminum flashing should do the trick. You can also use aluminum insulation tape to close small gaps. The spray stuff would work too, just might be a bit messy.
On my racecar I lowered oil temps by 20 degrees doing the above.
I see Peter in the background in that pic!
Old 07-30-2022, 07:14 AM
thanks liter. great idea
st.. thanks. good ideas.. are you talking about that tape for weatherstripping and sealing window cracks? or something else? problem with the flashing is that there is no room to get the rivet gun in there. even the manual one. the aluminum. tape might work for small stuff but I bet would not hold up to much air pressure..
yes classic Peter with the cigar at lime rock!
Old 07-30-2022, 07:24 AM
Bill Verburg's Avatar
I've used those foam pipe insulation tubes, they come is multiple widths,
very easy to work w/
Bill Verburg
Old 07-30-2022, 07:25 AM
It's a 914 ...
Yep, weatherstripping tape. It's convenient that it has the tape built in to secure.
If the spot is hard to get to, stuffing foam in there should do the trick though.
Old 07-30-2022, 07:54 AM
Bill V./liter. this is just that brown dense foamy stuff that is split down the middle you wrap pipes with? ? so you just cram it into the gaps and glue/tape or something to hold it? thanks. frank
Old 07-30-2022, 08:40 AM
2” wide aluminum duct tape, get the thickest aluminum. It should hold up to air pressure, self adhesive peel and stick.
Old 07-30-2022, 10:33 AM
Mahler9th's Avatar
Not sure I understand:
"...you cannot shape any metal to fit it properly."
Do you have or can you take pictures?
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 07-30-2022, 10:40 AM
yes, w/ the right size just cram it in and it will stay put. It is pretty compressible and bendable
Bill Verburg
Old 07-30-2022, 12:07 PM
I like the foam rubber pipe insulation tubes available at any home improvement store. I believe they have been the go-to for this application for as long as any of us can remember.
I like the stuff that has the "stickum" on both sides of the seam where it is split. There is a cellophane peel-off protectant strip on each side so they don't stick together. Get the surfaces to which you would like these to stick as clean as possible, cut to length, peel the cellophane, and stick in place. So cheap it might as well be free, and it stays in place for a good long time.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 07-30-2022, 02:02 PM
THANk you EVERYONE superb advice. as usual from the brain trust. cheers. frank
Old 07-30-2022, 03:11 PM
Under the radar
Trackrash's Avatar
I have resorted to that spray foam crack sealant.
Never could get that stick on foam weather stripping to stay put. Kind of embarrassing when you have it dragging under the car.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-30-2022, 05:26 PM
Cory M's Avatar
The stick on foam that is used as a gasket under 911 fuel tanks works good for this purpose. The adhesive is really sticky and the foam conforms well, as long as it's thick enough for your application.
Old 12-02-2022, 10:51 AM
Thanks Cory. thats an excellent suggestion. Indeed its REALLY sticky !
Old 12-03-2022, 06:23 AM
