How do I disable that annoying buzzer on start-up?
My '78 911 has a small symbol for seatbelt and brake on the dash
which lights up and sounds a VERY irritating buzzer when the ignition key is engaged, even when the belts are fastened. Solutions appreciated. ................... ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++++ |
pop out the gas gauge, reach in and pull it out. should be easy to locate, with all the noise it makes. if the gas gauge hole is too small for your hand, the next hole over will work too.
Thank you! I want to do the same to my 79 SC. I hate that damn buzzer.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
This is the first thing I pulled out when I got my '79SC:
![]() I remember that I was able to pull it without removing any gauges. I think I just reached under the dash and felt where the sound and vibrations came from.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold Last edited by porwolf; 11-10-2014 at 03:59 PM.. |
Rescuer of old cars
Oh no, you can't pull the buzzer! It's an original part, your car will be worth much less w/o it!!
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
I was able to reach my relay through the front trunk.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
Enginerd
Adding to this old thread....I have an '82 SC, just replaced my ignition switch (40 y.o. switch failed).
I found an easier way to disable the key switch buzzer, just remove the black connector next to the ignition switch/lock assembly.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
The buzzer was above the glovebox
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Registered Minimalist
On my 75 if you remove that relay the car wont even start.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
