Crotchety Old Bastard
RarlyL8's Avatar
Door Locking Mechanism Parts?
I'm helping a friend who is doing a nuts/bolts resto-mod on a Euro 930. The car was taken to a shop to be stripped down before Covid hit and was trapped there for 2 years during lockdowns and other challenges. Long story short, the shop "misplaced" many of the parts stripped off the car and damaged other parts. He has sense retrieved the car and is now dealing with the difficulty of replacing these parts. Most of the damaged parts were able to be repaired and many of the missing parts reproduced or purchased new from Porsche at great expense. There are some parts that are just too expensive to buy one bolt at a time so I'm going to help him track down some good used parts.
Currently he is installing the doors and has discovered many parts of the door mechanism are missing. In the schematic below he is missing #'s 16, 17, 29 & 30 but will purchase the entire assembly if anyone has this.
Here is a photo of the car at the shop before he retrieved it. Parts were not properly bagged or marked and apparently many walked away. I can't imagine having to load up a truck with unidentified parts and attempt to put it all back together again.
Old 12-14-2022, 08:40 AM
proporsche's Avatar
i have the 29 new if you need 2 but i`m in Europa..but i will be in Florida in January
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-14-2022, 09:30 AM
donbecker1234's Avatar
Currently redoing my door mechanisms as well so I might be able to help.
At some point, the original G body parts were superseded by a later generation (964? 993?)
Note that 29 is different per side.
Relay lever left 99353108300 Diagram 29
https://www.pelicanparts.com/More_Info/99353108300.htm?pn=99353108300&KeepHeader=Y&ByPassCat=Y
Relay lever right 99353108400 Diagram 29
https://www.pelicanparts.com/More_Info/99353108400.htm?pn=993-531-084-00-OEM&q=99353108400
Door lock pull rod (need 2) 99353109102M100 Diagram 30
https://www.pelicanparts.com/More_Info/99353109102.htm?pn=993-531-091-02-M100&q=9935310910
Bowden cable for inner door latch (need 2) 91153150901 Diagram 26
https://www.pelicanparts.com/More_Info/91153150901.htm?pn=911-531-509-01-OEM&q=91153150901
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine
Old 12-14-2022, 12:54 PM
I should have all the parts
Something I'm doing wrong, I can't upload pictures right now
Lorne M.
83 SC
Old 12-17-2022, 08:17 PM
proporsche's Avatar
Hi Brian, i have these parts if you would need some of them let me know
Ivan
Old 12-18-2022, 01:23 AM
