930 clutch release fork question
The clutch kit on my friend's 77 930 came from Kennedy Engineering with a throwout bearing that has 2 fingers facing out. These should engage with the release fork and be pulled outward to release the disc. But the fork that came with the short nose 4 spd trans had fingers that face the wrong way. Most of the parts diagrams show the throwout with a engaging groove and a fork with pins to fit in the groove. But other technical manuals that we have show the throwout with the fingers as on our clutch. Has anyone on the forum run into this problem? Is there an alternate clutch fork that would work with our clutch? If so -what is the correct part number?
Thanks in advance for your help! |
This is our release form
I wonder if they gave u parts for long bellhousing conversion to lightweight (small) clutch pressure plate?
Looks normal to me. Rotate the pic 90 degrees counter clockwise and that's how it sits in the bellhousing. Roll pin hole at the top. The fingers fit under the t/o bearing ears.
Post a picture of release bearing. John is right.
Ok-will give it another go on Monday
as John W. said you are fine..i have one here on table look the same...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Got it back together, and it looks like it should work this time! Thanks for all the comments
