17"Fuchs on 82 SC Targa
Hello fellow 911's,
I am currently rebuilding a 82 SC Euro Targa, and would like to fit 17' Fuch Wheels on it. What would be the ideal offset and size of tyres to fill out, but not go wider than the wheel arches? Also I dont want to widen or roll the fenders. Need help pls. TIA |
Fuchs never made 17" rims for the 911, only 14", 15" and 16", with various offsets.
You can get a number of aftermarket Fuchs design rims in 17" for the 911. I would suggest the Rota Fox 7.5"x17"ET36 with 225/50-17 and 9"x17"ET16 with 255/45-17 tires. They will fit SC and Carrera from 1974 to 1989 with the 9" rear quarter panels. The downside of the cast aftermarket rims compared to the forged original Fuchs rims, are that a 17" Fuchs copy weigh twice as much as a 16" Fuchs original. The weight difference has a very noticeable adverse effect on acceleration and handling. The upsides of 17" rims are that they are cool looking and have a much larger selection of tires. I have the above mentioned Rota Fox wheels and tires on my 911, and I would have changed to 16" if I did it over again. I would have had 951 wheels up front, 8"x16"ET 23.3 with 225/50-16 and 9"x16"ET15 with 245/45-16.
1985 928 S3, 5-speed 1987 Carrera, current project 2012 Jaguar XF 5.0, Wife's d.d. 2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's... |
Driver
Does Rota still make their Fox replica? I've had (fast) friends with those wheels, and they've been happy with them. There are a couple other companies that have made 17" Fuchs replicas. Euromeister, Maxilite, and another company whose name escapes me at the moment. I think Maxilite is the only one still making them (?), if OP is looking for a new set.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
17" fuchs are available, and light. Even better than the old ones.
A set of of 7" and 8" in 17" would look great on the car. https://www.fuchsfelgeusa.com/wheels/ |
This is a friend's Carrera on 17s
First: everybody is free to modify the own car on it's personal taste and intention.
But: I'll never get what a bigger and heavier wheels should make better on those cars except the look and stance - and still this look looks wrong on a G body car. The ride construction is oriented on 15" and 16" rims. 16" are the preferred size due the tire is more stretched/fixed on the rim than on 15" wheels with thicker/fattier tire sidewalls where the rubber can move much more (which is undesired of course!). For performance improvement everybody chases for weight reduction, power improvements and tunung. But on the most important connection between the car and the ground we're talking now about bigger wheels and more weight? Seriously? Even the new 17" Fuchs rims are less than 3lbs/1kg heavier than the 16"s - it's no argument for me. Just my 2cts. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 09-09-2022 at 04:47 AM.. |
original Fuchs 7s are ~14#, 8's are ~19# new Fuchs 16x7 are ~12.3# and 8s ~12.7#, 9s~13.4# Fuchs Gefekge 17 x7 are ~16.5# and 8 ~17# and 9~17.5 Fikse Fuchs 7x17 are ~14# 8s ~15# 9s ~16# but more importantly in order of increasing importance to performance, not counting minor things like lug nuts, caps and balancing weights brake rotor weight < wheel weight < tire weight < tire OD here's a comp of original 16s vs Fikse 17s ![]() theres a net gain of torque available for acceleration of ~.7lb-ft, That of course is subject to change from using different wheels or tires to the original poster you can go up to 8ET27 w/ 225/45 x17(or even 245/40)and 9.5 ET19 w/ 255/40( or even 275/35) but for the easiest fit w/o mods or suspension 7.5 ET28 215/45 and 9ET15 245/40
Yeah, I know what you mean. I had VERY heavy 17" Carrera Cup fakes on the SC. I loved the look, but it felt like I was driving around with the handbrake/emergency brake on. Once I swapped back to the factory fitted 16" wheels it felt like a 20hp power increase and snappier handling. I think the 17" wheels will make good wall art in my new garage LOL
The new Fuchs 17" rims are not for made for 911, but for 964 and 993, with 55mm offset. You would need insane spacers to make those fit on a 911.
Again it is the tire od is far more important
If you really care about performance go w/ 15s here's a 41lb ft gain over an efficient 17 w/ 15s ![]() here's an efficient 16 vs an efficient 15, the 15s have a 20lb-ft edge ![]() here's 15 vs stock 16s, ~38lb-ft extra for the 15s ![]()
15’s ftw. best look on a g series
‘70 911E ‘82 911 SC Targa ‘86 944 Turbo ‘90 OM606 Swapped SWB 300GD IG: @JackSchroederCreative |
Carmagic.us
Just for information the Euromeister are 19Lbs for the 7x17 and 20Lbs for the 9X17
I use 215/45 at front and 245/40 at the rear. They are still available in Europe. Both cars on the same setup. Left 84 and at the right 82 ![]() ![]() Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Rothaus, those 17th by 9 + tire size just look amazing on the rear of the 82!
Behind the wheel in my US imported 81 SC with 3.2L swap. |
