Is it possible to separate the rear parcel shelf?
I have two parcel shelves that I'd like to swap bottom panels. My question is, is it possible to separate either panels without damaging them?
I snagged this photo from the classifieds.
Old 01-31-2023, 10:16 AM
myamoto1's Avatar
Yes. I did this on a 993 parcel shelf. I'm not sure how the older shelf is attached, but the 993 is mostly staples and a little adhesive.
Josh
85 M491 Coupe - "Fat Bastard"
Old 01-31-2023, 10:53 AM
How do you staple it back together?
Thanks for the help!
Old 01-31-2023, 02:04 PM
seafeye's Avatar
If you bend up the staples you can separate the parts. It’s 3 pieces. The vinyl is wrapped around. Kinda hard to explain but once you bend the staples up you’ll easily see how it comes apart. Two different size staples will be required to assemble.
Old 01-31-2023, 02:54 PM
