‘77 C3.0 Engine Cohline Suppy/Return Hoses
I need to replace both supply and return fuel hoses from the rear tunnel exit to their appropriate connections in the engine compartment. One goes to the accumulator and the other to the fitting by the rear intake runner by cylinder #3.
These are the two part numbers I’ve come up with, but I’m unsure if the tunnel end fitting is correct.
911-356-066-16 Supply
https://www.pelicanparts.com/More_Info/91135606616.htm?pn=911-356-066-16-OEM
911-356-062-15 Return
https://www.pelicanparts.com/search/?q=911-356-062-15+
