1978 911 SC
Question about Bilstien HD front struts
Purchased a set of lightly used Bilstein HD front struts. Curious if there should be a bumper stop or washer that goes between dust shield and strut housing.. here is a picture of what I have. Any help would be amazing. Cheers
1978 911 SC
If they are bilstein for the boge strut then the bump rubber is inside the shock
if all bilstein then the bump rubber must be added to the small dia piston that goes down into the strut . sometimes we cut off one dough nut to 1.5 .
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 02-04-2023 at 10:29 AM.. |
That is all bilstein
if all bilstein then the bump rubber must be added to the small dia piston that goes down into the strut . sometimes we cut off one dough nut to 1.5 just slide the dust shield onto the top of the strut
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
1978 911 SC
icarp, thank You very much !! Back to the garage I go. Cheers 🍻
