Front sway bar question
If I disconnect my front through-body swaybar to clean up and reconnect in the same position will this affect my alignment? Thanks
1980 911SC Targa 3.6L
Old 02-02-2023, 12:31 PM
Bill Verburg's Avatar
not unless you are running a ton of preload
Bill Verburg
Old 02-02-2023, 12:44 PM
Racer
winders's Avatar
If you disconnect and then reconnect the swaybar without changing anything in that connection, the car will be the same before and after.
If you have preload in the swaybar setup, that will affect corner balance and may affect alignment compared to when the swaybar is disconnected.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-02-2023, 12:50 PM
